Setfields inoutlet and water and air patches
Old   September 29, 2008, 08:40
Default dear all, i have, using block
erik023
dear all,
i have, using blockMesh, created a domain which has separate in/outlet for water and for air. then, using snappyhexmesh, i placed a boat in my domain (3D) and now i like to let water flow in/out through my waterpatches. when using interFoam it explodes. i get the impression that after filling the bottom part of the domain with water (modifiing the dambreak case for interfoam) i get air (or what?) to flow in to my domain. is there a way to specifiy that i like water to flow in to my lower patch and air in to the upper patch?
is it clear what i try to do?
Old   September 29, 2008, 10:05
Default Hi Erik Have you tried to s
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Erik
Have you tried to set the value of gamma on the specific patches to the value you want, e.g. on water-inlet set gamma to
type fixedValue;
value uniform 1;
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Problem about setFields williamscn OpenFOAM Pre-Processing 23 December 9, 2018 00:15
SetFields runs with no errors but doesnbt change fields adamsview OpenFOAM Pre-Processing 3 December 12, 2014 21:03
InterDyMFoam and problem with setFields chris_sev OpenFOAM Running, Solving & CFD 1 March 23, 2009 21:23
[Gmsh] How to define these patches zhoubinwx OpenFOAM Meshing & Mesh Conversion 6 September 15, 2008 08:52
Regarding setFields file 21kalee OpenFOAM Running, Solving & CFD 0 January 14, 2008 05:42
