FOAM FATAL IO ERROR size 1 is not equal to the given value of 26776
Old   July 12, 2008, 15:58
Default Hi everyone, I have workin
Hari Krishnan
hariya03 is on a distinguished road
Hi everyone,
I have working with a simpleFoam case to see the flow of air from a inlet to outlet on a specified path.
The mesh has readed from a third party client and boundary patches are set in constant/polymesh.
The control dictionary were set to read for 300 as end time with a write interval of 100.
The fvsolution &t the intial boundary conditions
are feeded.
When I running the '0' time folder for simpleFoam
I got the following error
Application started with pid 22270
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : simpleFoam /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam smartvalve12
Date : Jul 11 2008
Time : 16:48:44
Host : D6
PID : 22270
Root : /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
Case : smartvalve12
Nprocs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR : size 1 is not equal to the given value of 26776
file: /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam/smartvalve12/0/U from line 28 to line 229.
From function Field<type>::Field(const word& keyword, const dictionary& dict, const label s)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Field.C at line 224.
FOAM exiting
Kindly advice me where i did wrong
If you need any further information, kindly ask me.
Thank you,
V.Hari
hariya03 is offline   Reply With Quote
Old   June 13, 2013, 15:53
India
mayank.dce2k7 is on a distinguished road
I am also working on a problem and encountering the same error. Did you find a solution for this error?
Regards,
Mayank
mayank.dce2k7 is offline   Reply With Quote
Old   June 13, 2013, 17:22
Lieven
Lieven will become famous soon enough
Hi Mayank,
Welcome to the forum. Since the first post dates from 2008, I doubt Hariya03 will reply ;-).
For which field do you get this error? Can you post your boundary conditions file of this field (the file in the 0-folder)?
Cheers,
L
Lieven is offline   Reply With Quote
Old   June 14, 2013, 02:11
India
Hi Lieven,
Thanks for your reply.
The problem is solved.
I am very new to OpenFOAM. As a part of my thesis, I have to run simulations on OpenFOAM involving fluid particle dynamics.I am trying to set up a 'one way coupled' case for running application 'icoUncoupledKinematicParcelFoam' on a standard driven cavity as a test case. Below is my approach:
1.) I ran 'icoFoam' driven cavity tutorial and picked up the velocity field(U) from the directory created at last time step i.e 0.5.
2.) I used this velocity field as a pre-defined velocity field for running 'icoUncoupleKinematicParcelFoam' by putting in this velocity field inside '0' directory of a new case set up using the same driven cavity mesh. This time I included all the necessary files required like 'KinematicCloudProperties', 'KinematicCloudPosition', 'turbulence properties' etc.
3) The case ran fine without errors.
Is my approach for setting up one-way coupled cases using a pre-defined steady velocity field ok or is there a better way for performing one way coupling? Also, I am new to this forum please guide me if I am asking this question at a wrong place.
Regards,
Mayank
Error size 400 is not equal to the given value of 1681 alimansouri OpenFOAM Running, Solving & CFD 8 August 7, 2018 07:26
FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 4 July 30, 2008 10:06
Parallel FOAM FATAL IO ERROR msrinath80 OpenFOAM Running, Solving & CFD 1 July 28, 2006 12:48
FOAM FATAL ERROR derath OpenFOAM Pre-Processing 1 June 10, 2006 14:20
FOAM FATAL IO ERROR sita OpenFOAM Running, Solving & CFD 2 August 23, 2005 04:37
