The u file
Old   June 30, 2008, 22:30
Default hi, I am doing a simulation,i
weihong yao
ivanyao is on a distinguished road
hi,
I am doing a simulation,it is about the wind pressure on the building.there is a problem to set the velocity of the wind.It is ok to set the velocity by a exactly value,such as 5m/s,8m/s.but the fact is the velocity of wind is change by the height,such as 0.2Z(Z is the height of the building.)and I don't know how to fix it. I am very appreciate if someone can help me.thanks.
ivanyao is offline   Reply With Quote
Old   June 30, 2008, 23:28
Default I think , you can do that usin
KaLee_Kun
kaleekun is on a distinguished road
I think , you can do that using funkySetFields executable...
If you are not successful with that, see sonicFoam's setShock utility. You will get some idea in doing it
kaleekun is offline   Reply With Quote
Old   July 5, 2008, 02:29
Default thanks
weihong yao
thanks
Old   July 7, 2008, 06:37
Default Hi! Our Laboratory-made-uti
Masashi IMANO
imano is on a distinguished road
Hi!
Our Laboratory-made-utility setDiscreteFields would help you.
This utility can set profiles of any vector/scalar fields at specified boundary patches with using discrete profile data.
See setDiscreteFieldsDict in the attached archived file for details!
setDiscreteFields-1.0.tar.gz
imano is offline   Reply With Quote
Old   July 7, 2008, 08:36
Default I know, that's a stupid questi
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
I know, that's a stupid question, but,
where do I have to put the setDiscreteFields to compile it correctly?
ivan_cozza is offline   Reply With Quote
Old   July 7, 2008, 11:14
Default Hi, Ivan! Any locations cou
Masashi IMANO
Hi, Ivan!
Any locations could be used for the proper compilation!
But I usually put source of this kind of non-standard utility
at $WM_PROJECT_USER_DIR/applications/utilities.
In this case the compilation commands would be described like:
$ cd $WM_PROJECT_USER_DIR/applications/utilities
$ tar zxf setDiscreteFields-1.0.tar.gz
$ cd setDiscreteFields
$ wmake
Masashi
PLOT3D ASCII solution file to MATLAB data file Sandeep Rana Main CFD Forum 4 June 11, 2010 09:48
[OpenFOAM] ParaView exiting while trying to save image file or movie file 21kalee ParaView 3 January 23, 2008 16:01
Changing gambit file without change of case file?? Asghari FLUENT 2 August 28, 2006 13:48
Covert gambit file to polyflow file John FLUENT 5 August 6, 2004 08:31
Converting a surface file to a volume file Amir FLUENT 2 December 30, 2002 04:53
