I am trying to run FoamX and i
I am trying to run FoamX and it fails with the following error:
Starting NameServer with inet:headnode.hpc.here.edu:1234 ... uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed) /home/cfr100/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 135: 13443 Aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null I have no cases or case files and it has worked before. Someone else is already logged in and running FoamX, and their application is attached to port 1234. I think this is the problem. Am I correct? Any ideas on the solution? Thanks chuck |
I got the same problem with Ub
I got the same problem with Ubuntu gutsy (andLinux).
any resolution? Thank you. |
