November 9, 2007, 15:38 |
I have installed Ope
I have installed OpenFOAM on an X86_64 machine running RHEL 5 but cannot seem to get FoamX running. I have successfully created symbolic links for libssl.so.0.9.8b, libcrypto.so.0.9.8b, and libebl_x86_64-0.125.so. However, I have not been able to figure out how to resolve the following error (which I believe is related to libX.s0.6 symbolic link). [cmerrill@penguin ~]$ FoamX Starting NameServer with inet:penguin.ara.wan:1234 ... Starting FoamX Host Browser with inet:penguin.ara.wan:1234 ... /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : Nov 09 2007 Time : 15:20:34 Host : penguin.ara.wan PID : 3688 Root : Case : Nprocs : 1 HostBrowser running..... Setting LANG to en_EN Using jar /home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/Foam X/lib/FoamX.jar Using jar /home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/Foam X/lib/jlfgr-1_0.jar Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/cmerrill/OpenFOAM/linux64/j2sdk1.4.2_05/jre/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader.loadLibrary0(ClassLoader.jav a:1586) at java.lang.ClassLoader.loadLibrary(ClassLoader.java :1503) at java.lang.Runtime.loadLibrary0(Runtime.java:788) at java.lang.System.loadLibrary(System.java:834) at sun.security.action.LoadLibraryAction.run(LoadLibr aryAction.java:50) at java.security.AccessController.doPrivileged(Native Method) at sun.awt.NativeLibLoader.loadLibraries(NativeLibLoa der.java:38) at sun.awt.DebugHelper.<clinit>(DebugHelper.java:29) at java.awt.Component.<clinit>(Component.java:506) /home/cmerrill/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 139: 3688 Killed FoamXHostBrowser -ORBNamingAddr $myIOP runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 3684). Any suggestions? I am a newbie. Thank you. |
November 9, 2007, 18:39 |
Search the forum for posts tha
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Search the forum for posts that suggest ways to solve the libXp.so.6 issue.
Eg: http://www.cfd-online.com/OpenFOAM_D...ges/1/394.html |
GAMBIT STARTUP error | Farhat | FLUENT | 3 | February 9, 2010 13:52 |
FoamX error | lawrencelkl | OpenFOAM Installation | 5 | May 23, 2008 01:29 |
FoamX libXpso6 wrong ELF class error | abanerj3 | OpenFOAM Pre-Processing | 2 | May 18, 2008 15:32 |
FoamX error | derath | OpenFOAM Pre-Processing | 2 | April 25, 2007 05:51 |
Gambit startup error: libXp.so.6 cannot be found | Patrice Guay | FLUENT | 5 | August 10, 2005 13:03 |
