January 21, 2006, 19:39 |
I have to model a pipe with a
Alberto Passalacqua
Rep Power: 36 |
I have to model a pipe with a circular corona inlet all around the pipe circumference.
I have to specify a velocity normal to this boundary. How can I do it in OpenFOAM? Thanks in advance Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
January 23, 2006, 04:30 |
surfaceNormalFixedValue (in Op
Mattijs Janssens
Rep Power: 26 |
surfaceNormalFixedValue (in OpenFOAM/lnInclude/surfaceNormalFixedValueFvPatchField.H)
needs a 'refValue' entry which is the outwards pointing velocity (so negative for inflow) |
January 23, 2006, 17:30 |
Thanks!
Alberto Passalacqua
Rep Power: 36 |
Thanks!
June 21, 2007, 10:12 |
it seems that I have a
Fabian Braennstroem
Rep Power: 19 |
it seems that I have a similar problem... I would like to calculate a hvac duct and have to set the inlet velocity normal to the boundary. Unfortunately, I do not understand, what Mattijs wrote as a hint!? Regards! Fabian |
June 21, 2007, 14:11 |
If the boundary is flat, use f
Alberto Passalacqua
Rep Power: 36 |
If the boundary is flat, use fixedValue and specify the appropriate components of the velocity.
If it's not flat You can use: type surfaceNormalFixedValue; refValue uniform Umag; As Mattijs said, if you want your flow to enter your domain, Umag has to be negative. Regards, Alberto
June 22, 2007, 02:39 |
On a similar note, if I
On a similar note, if I were to simulate boundary layer suction or blowing, would it be valid to use an ordinary wall boundary condition with a (strictly) normal velocity specified (either by using fixedValue or surfaceNormalFixedValue), or would a specialized boundary condition need to be build? Also, could, for moderate normal velocities, a wall function still be used? Or will a low-Re turbulence model be required? best regards, Roland |
July 3, 2007, 08:16 |
Hi Alberto,
thanks for the
Fabian Braennstroem
Rep Power: 19 |
Hi Alberto,
thanks for the help! Regards! Fabian |
WALL normal velocity | Luca | Main CFD Forum | 1 | October 8, 2014 05:21 |
Opening BC: Normal to boundary | Jan Ramboer | CFX | 3 | September 21, 2007 15:06 |
velocity normal to the surface | srinivas | Siemens | 1 | May 30, 2007 02:03 |
Velocity gradient normal to a wall | ap | FLUENT | 0 | July 26, 2004 08:32 |
Shear and normal stress on a boundary | Fing | CFX | 2 | May 27, 2004 01:47 |
