March 24, 2006, 05:48 |
as simpleFoam is a stea
Anja Stretz
Rep Power: 17 |
as simpleFoam is a steady-state solver, the defined "timestep" is an iteration counter. Does that mean, that the "endTime" is the max number of iterations? And why is then within each timestep an iteration of p (in my case only in the beginning of the calculation, problem follows) I want to calculate u and p but: Time = 999 AMG: Solving for p, Initial residual = 1.02579e-06, Final residual = 2.76786e-07, No Iterations 1 time step continuity errors : sum local = 6.13966e-06, global = 5.96414e-08, cumulative = 0.000117451 ExecutionTime = 9411.37 s Time = 1000 time step continuity errors : sum local = 1.01213e-05, global = -4.50328e-08, cumulative = 0.000117406 ExecutionTime = 9419.22 s Thanks a lot for your help! Anja |
March 24, 2006, 05:59 |
Yes, endTime is the max iterat
Hrvoje Jasak
Rep Power: 33 |
Yes, endTime is the max iteration count. However, based on the snippet of the log file, you run has converged a long time ago. What you are seeing are the oscillations in the pressure due to round-off.
Have a look at the point where the momentum equation was solved last - this is where you should have stopped the solver. Note: the convergence checks in simpleFoam may be somewhat different to what you're used to: for example, if you want to converge the global residual to 1e-6, you should specify the linear solver convergence to be lower. Otherwise, as you approach the global convergence tolerance, the solver stops doing the work and nothing much happens. I personally always check the global convergence by hand (well, eyes) :-) Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
March 24, 2006, 07:20 |
Well, this is what I was using
Anja Stretz
Rep Power: 17 |
Well, this is what I was using:
p AMG 1e-06 0 100; U BICCG 1e-05 0.1; What would you change? How do you check the global convergence? THANKS! |
April 5, 2007, 09:28 |
Hi world,
I am in the same
Hoang-Lam
Rep Power: 17 |
Hi world,
I am in the same situation like Anja: I want my computation to stop when it reachs the criterium of convergence that I precise (the solver tolerance in system/fvSolution file, isn't it?), and not in function an arbitrary number of iterations (endtime, in system/controlDict in file). Can somebody help me to do this, please? Thanks in advance, Lam |
OpenFoam profiling the solver simpleFoam | andre | OpenFOAM Programming & Development | 9 | April 29, 2017 08:51 |
SimpleFoam as Newtonian laminar flow solver | titio | OpenFOAM Running, Solving & CFD | 2 | March 8, 2013 04:44 |
Steady incompressible laminar flow using simpleFoam | yongshenglian | OpenFOAM Running, Solving & CFD | 0 | October 29, 2008 15:28 |
Dimension change in solver like simpleFoam | booz | OpenFOAM Running, Solving & CFD | 2 | August 21, 2008 11:35 |
SimpleFoam for laminar flow | hsing | OpenFOAM Running, Solving & CFD | 3 | April 14, 2005 14:39 |
