FoamX canbt find applications
Old   January 23, 2006, 08:37
Default I'm new to OpenFoam, so forgiv
Carlos Rodriguez
ingaerme is on a distinguished road
I'm new to OpenFoam, so forgive me is this is an obvious question. On several cases I've been running, FoamX complains that it cannot find the application that appears in the ControlDict file. As a result it does not allow me to open the case. An example is the 'aachenBomb' case in the dieselFoam tutorial, where the following error message appears as soon as I click on the case:
"The OpenCase operation failed due to
getApplication::Invalid application class name dieselFoam"
Now, the dieselFoam application obviously exists. I had a similar problem with the reactingFoam application. I know there has to be a configuration file somewhere, but I cannot find it. The user guide is not helpful either. Thanks.
ingaerme is offline   Reply With Quote
Old   January 23, 2006, 13:37
Default Some applications were never s
Mattijs Janssens
mattijs is on a distinguished road
Some applications were never set up in FoamX.
Check the original application directory (in the solvers directory) for a FoamX directory with .cfg files.
mattijs is offline   Reply With Quote
Old   January 24, 2006, 08:37
Default Mattijs, If by original dir
Carlos Rodriguez
Mattijs,
If by original directory you mean
$HOME/OpenFoam/OpenFoam-1.2/applications
I couldn't find any FoamX directory there. The closest is the directory
.../applications/utilities/preProcessing/FoamX
but I didn't find any .cfg file there. The only other place where I could find .cfg files is
$HOME/OpenFoam/OpenFoam-1.2/.OpenFoam-1.2/apps/FoamX
where there is a whole bunch of .cfg files. I looked inside the ones that seemed more obvious, but couldn't find any list of solvers.
Could you be a bit more specific about the directory and file I should be looking for? Thank you for your help.
Carlos
Old   January 24, 2006, 14:34
Default Every FoamX configuration setu
Mattijs Janssens
Every FoamX configuration setup is bundled with the solver. E.g. for icoFoam the source directory ($FOAM_SOLVERS/incompressible/icoFoam/) has a FoamX subdirectory with all the solver specific configuration.
My guess is that those two solvers you mentioned were never setup in FoamX.
Old   January 25, 2006, 08:12
Default Mattijs, That's what I need
Carlos Rodriguez
Mattijs,
That's what I needed to know. Thank you for your help.
Carlos
Old   February 2, 2006, 23:52
Default Hi, Mattijs, If we setup ou
Masato Otsuki
otsuki is on a distinguished road
Hi, Mattijs,
If we setup our own application directry outside
of $FOAM_SOLVERS, FoamX doesn't search *.cfg
in such a directry. Is it true ?
I don't prefer to put customized solver under
$FOAM_SOLVERS. How to solve this ?
Masato
otsuki is offline   Reply With Quote
Old   February 3, 2006, 04:04
Default It also scans $WM_PROJECT_USER
Mattijs Janssens
It also scans $WM_PROJECT_USER_DIR/applications/solvers and $WM_PROJECT_USER_DIR/applications/utilities.
so you can put your specialized solvers in there.
Old   February 6, 2006, 04:34
Default Thanks !
Masato Otsuki
Thanks !
Old   December 12, 2006, 14:56
Default Hi, Mattijs, Is there any u
Ram Poudel
rcpoudel is on a distinguished road
Hi, Mattijs,
Is there any userguide for OpenFOAM without GUI (like FoamX) or which does not use GUI?
rcpoudel is offline   Reply With Quote
Canbt start a new thread cwang5 OpenFOAM 1 January 14, 2009 05:21
OpenFOAM14 linux64 paraview canbt find libtcl84so and libtk84so hoogland OpenFOAM Installation 5 June 26, 2008 12:38
Error while compiling FoamX related applications geoffjay OpenFOAM Installation 2 May 7, 2008 19:43
A new RunFoamXHB problem canbt start FoamX alondono OpenFOAM Pre-Processing 0 January 26, 2007 22:14
Help I canbt run FoamX report Unable to contact name server error cornerstone OpenFOAM Installation 0 May 3, 2006 01:14
