Choked Nozzle : BC using Total Pressure
Old   September 1, 2009, 06:09
Default Choked Nozzle : BC using Total Pressure
Cosimo Sinesi
CSinesi is on a distinguished road
I'm trying to obtain using OpenFoam the same results obtained in a test, but I have some problem setting the BC. I searched in the manual, in the forum but I didn't find anything working.
I have the following boundaries:
nozzle_exit:
I need to set Total Pressure, Total Temperature and Static Pressure
In Fluent I use Pressure Inlet
po:
These are the 6 sides of the cube that contains the scenario, implemented in Fluent using Pressure Outlet (Pressure and Temperature)
Any suggestion? How should be p T and U files?
Thanks
CSinesi is offline   Reply With Quote
boundary conditions, choked, nozzle, total pressure
Total pressure exceeds inlet value Tom CFX 1 September 9, 2008 22:02
conservative total pressure and density Atit Koonsrisuk CFX 0 June 24, 2007 12:45
difference between total pressure and static press kiran Main CFD Forum 5 June 8, 2005 09:23
total pressure in CFX Atit Koonsrisuk CFX 0 January 1, 2005 05:46
Total pressure to static pressure ratio roadracer Siemens 1 April 17, 2003 05:31
