October 6, 2006, 13:24 |
Hi All!
I have a problem wi
Simon Zhang
Rep Power: 17 |
Hi All!
I have a problem with opening FoamX. The messages are pasted below. It seems like I cannot get the HostBrowser working. I am a beginner and I'm using Fedora 5. Could someone please help me solve this problem? I've been searching the old threads here but cann't find the right answer for this. It still not working after I tried every suggestions for similiar problems. Many Thanks!! Simon [simon@BILDMLINUX ~]$ FoamX Starting NameServer with inet:BILDMLINUX:1234 ... Starting FoamX Host Browser with inet:BILDMLINUX:1234 ... FoamXHostBrowser: error while loading shared libraries: /home/simon/OpenFOAM/OpenFOAM-1.3/lib/linuxGcc4DPOpt/libFoamX.so: cannot restore segment prot after reloc: Permission denied runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 4950). /home/simon/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 66: 4950 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null |
October 7, 2006, 07:57 |
You could check:
- does anyth
Mattijs Janssens
Rep Power: 26 |
You could check:
- does anything else run fine? e.g. blockMesh, or icoFoam. - are you using the correct c++ compiler for your OpenFOAM version? - if other programs run correctly maybe libFoamX (uses MICO libraries) was not compiled correctly? |
You could check:
- does anyth
Mattijs Janssens
Rep Power: 26 |
You could check:
October 8, 2006, 18:53 |
Hi Mattijs,
Yes, the blockMes
Simon Zhang
Rep Power: 17 |
Hi Mattijs,
Yes, the blockMesh and icoFoam are running fine. I believe I am using a correct c++ compiler cuz I download everything from the download page. Sorry I am very fresh to this. I didn't do anything except unzip all the files and putting them into recommended folders. Then I tried to run FoamX and it gives the libelf.so.0 problem, which I have fixed according you guys help in one old thread. Does it compiles every time it runs? Thank you for your time on my maybe ignorant question. |
October 9, 2006, 03:56 |
Looks weird.
- check what
Mattijs Janssens
Rep Power: 26 |
Looks weird.
- check what libraries libFoamX.so pulls in with ldd. - recompile Mico See $FOAM_SRC/Allwmake, section on Mico on how to recompile it. - recompile FoamX. See $FOAM_UTILITIES/preProcessing/FoamX/Allwmake. |
October 10, 2006, 15:01 |
Hi Mattijs,
I check the lib
Simon Zhang
Rep Power: 17 |
Hi Mattijs,
I check the libraries that libFoamX.so pulls with ldd. Here is the info it comes out. I have no idea what it says. I am recompiling Mico using $FOAM_SRC/Allwmake. It seems it will take a while to finish....I'll let you know once it is done. Everything else works pretty well. Is that possible something was screwed up when the IT guy helped me set up the Fedora Systems? Because I think something might be wrong with the host setup. Thank you again for your help! [simon@BILDMLINUX linuxGcc4DPOpt]$ ldd libFoamX.so linux-gate.so.1 => (0x00f14000) libdl.so.2 => /lib/libdl.so.2 (0x0074b000) libstdc++.so.6 => /home/simon/OpenFOAM/linux/gcc-4.1.0/lib/libstdc++.so.6 (0x0074f000) libm.so.6 => /lib/libm.so.6 (0x00dee000) libgcc_s.so.1 => /home/simon/OpenFOAM/linux/gcc-4.1.0/lib/libgcc_s.so.1 (0x0082f000) libpthread.so.0 => /lib/libpthread.so.0 (0x0083a000) libc.so.6 => /lib/libc.so.6 (0x0084e000) /lib/ld-linux.so.2 (0x009b5000) |
October 12, 2006, 09:04 |
Problems remains the same afte
Simon Zhang
Rep Power: 17 |
Problems remains the same after recomplied FoamX amd MICO...
October 12, 2006, 10:27 |
Try this:
http://www.cfd-onli
Dragos
Rep Power: 20 |
October 13, 2006, 09:35 |
Fantastic, problem solved!!
T
#9 |
Simon Zhang
Rep Power: 17 |
Thank you Dragos! |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
Problem in cavity flow problem | saad | Main CFD Forum | 4 | November 1, 2007 07:45 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
