November 28, 2005, 11:29 |
I am having some problem
Radu Mustata
Rep Power: 17 |
I am having some problem with the reconstructPar utiliy which worked fine until now and I do not seem to be able to locate it. The error that I am having is: Time = 0 Reconstructing FV fields Reconstructing volScalarFields p terminate called after throwing an instance of 'std::bad_cast' what(): St8bad_cast Aborted ...(this is decomposePar <my> and then reconstructPar <my>) Thanks, Radu |
November 29, 2005, 03:30 |
I face the same problem, with
Maka Mohu
Rep Power: 18 |
I face the same problem, with the standard channel tutorial case. But it works fine with cavity case.
November 29, 2005, 05:43 |
Hi Maka,
can you report thi
Mattijs Janssens
Rep Power: 26 |
Hi Maka,
can you report this as a bug? |
November 29, 2005, 07:10 |
Hi Mattijs,
I did. Thanks f
Maka Mohu
Rep Power: 18 |
Hi Mattijs,
I did. Thanks for your reply. /Maka |
November 29, 2005, 09:49 |
Bug solved in:
http://www.c
Maka Mohu
Rep Power: 18 |
November 29, 2005, 09:52 |
I already saw it. Frogot to ac
Radu Mustata
Rep Power: 17 |
I already saw it. Frogot to acknowledge it, though. Sorry about that.
Radu |
September 12, 2006, 09:23 |
I cannot access the link, and
Daniele Panara
Rep Power: 17 |
I cannot access the link, and I would like to know how to solve this bug, can anybody help?
Daniele |
September 12, 2006, 09:37 |
donīt have that problem anymor
Radu Mustata
Rep Power: 17 |
donīt have that problem anymore, and cannot even remember what was is about. I repeat, everything works fine for me right now.
Radu |
Bug in reconstructPar | david | OpenFOAM Bugs | 10 | May 26, 2009 12:11 |
ReconstructPar | kupiainen | OpenFOAM Post-Processing | 12 | April 21, 2009 01:47 |
[mesh manipulation] Error with reconstructPar | skabilan | OpenFOAM Meshing & Mesh Conversion | 3 | June 10, 2008 18:34 |
ReconstructPar | maka | OpenFOAM Bugs | 6 | August 22, 2007 04:23 |
ReconstructPar channelOodles error | maka | OpenFOAM Post-Processing | 6 | September 13, 2006 16:16 |
