Modifing reconstructPar to delete the reconstructed parallel directories |
December 13, 2005, 05:20 |
I'm solving a case with big nu
Maka Mohu
Rep Power: 18 |
I'm solving a case with big number of nodes and I need to save the instantaneous data. I need to modify the reconstructPar to delete the reconstructed parallel directories (within the reconstruction loop). I need to add an option to the command -savestorage which let the reconstructPar delete the reconstructed directory after reconstructing it. This can not be done at the end since the data are near a terra bite. I would be gratefule if any body can help.
Best regards, Maka |
December 13, 2005, 07:16 |
sorry repeated message.
Maka Mohu
Rep Power: 18 |
Modifying Source Files in Flow3D Directories | Xizao Yang | FLOW-3D | 3 | January 15, 2009 03:02 |
Time directories | robbo | OpenFOAM | 1 | May 21, 2008 16:49 |
Script for generating lnInclude directories | brooksmoses | OpenFOAM | 4 | January 26, 2006 19:02 |
Modify the reconstructPar to delete the reconstructed parallel directories within the loop | maka | OpenFOAM Post-Processing | 2 | December 16, 2005 10:37 |
Modifing grid in Gambit maintaining BC in Fluent | DavidS | FLUENT | 1 | December 21, 2004 02:53 |
