November 26, 2005, 09:07 |
Hi, everyone.
I have some q
Efimenko Evgenii
Rep Power: 17 |
Hi, everyone.
I have some questions about boundary conditions. 1.Is it possible in boundary condition specify only 2 vector components? I mean, for example, E.x=0, E.y=0, E.z - has arbitrary value(there is no any conditions) 2. If I don't have any conditions can I write "calculated"? I've tried, but it didn't work. It returns error. 3. Can I specify boundary conditions in solver code? Thank you Eugene |
November 26, 2005, 09:40 |
1 The (x y z) decomposition do
Hrvoje Jasak
Rep Power: 33 |
1 The (x y z) decomposition does not make sense to me - you probably mean "normal to the boundary" and "tangential to it" when you think about it a bit more. There is a directionMidex b.c. and a more general form which allows you to have a separate mixed b.c. on each component (normal and tangential)
2 "Don't have any conditions" in the FVM probably means zeroGradient. Try that. "calculated" is for special cases, where the code genuinely does not know the b.c., e.g. when it's doing fv calculus: consider the b.c. on div(U) :-) 3. Yes and no. If you build teh field completely in the code, you can give it a list of b.c.-s, but hooking them up and setting parameters in most cases requires casting. If you read the field from a file, and you know what the b.c. is, you can cast it in the code and mess about with it. Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
November 26, 2005, 10:04 |
Yes, I really mean that tangen
Efimenko Evgenii
Rep Power: 17 |
Yes, I really mean that tangential component is equal 0, and normal component doesn't have any conditions.
Yes, probably "zeroGradient" is something I need. Thanks a lot, it's very useful fo me |
Boundary condition for UDS | Tomik | FLUENT | 0 | December 5, 2006 17:37 |
Boundary condition of the third kind or Danckwertz boundary condition | plage | OpenFOAM Running, Solving & CFD | 4 | October 3, 2006 12:21 |
Slip Boundary Condition for Moving Boundary | Shukla | Main CFD Forum | 3 | November 11, 2005 15:02 |
UDF boundary condition | Jeff | FLUENT | 2 | November 20, 2003 17:15 |
Boundary Condition in LES | Zhang Tsiang | Main CFD Forum | 3 | February 5, 2002 20:15 |
