Running XFoam
Old   April 5, 2005, 07:10
Default Hello It's been a bit hard fo
Carlos H. Galindo-Lopez
galindolopez is on a distinguished road
Hello
It's been a bit hard for me to use FOAM. It was installed on a server basis and I ran the test example indicated in the README file. It ran with no problems... although I do not know where the results are (funny, I think).
Now I am trying to run FoamX (and FoamXHB), but I can't. I attach the error output:
[me078034@MEXP685C ~]$ runFoamX
ls: /applic/OpenFOAM/jobControl/runningJobs: No such file or directory
ls: /applic/OpenFOAM/jobControl/finishedJobs: No such file or directory
Jobs overview (from $FOAM_JOB_DIR):
Running : 0
Finished : 0
Some of the jobs reported as running might actually no longer be running.
You can these remove old jobInfo using the FoamX ProcessEditor or with the
foamCheckJobs script.
Starting NameServer with inet:MEXP685C.sme.cranfield.ac.uk:1234 ...
error: cannot open output file /applic/OpenFOAM/OpenFOAM-1.0.2/.OpenFOAM-1.0.2/apps/FoamX/ns.ref
[me078034@MEXP685C ~]$ runFoamXHB
I think I know the reason (missing Host and Port in the FoamXClient.cgf file)... Please confirm.
Are they (host/port) easily obtainable from the server unit?... (I do not manage the server and I want to ask for it the server manager providing help at the same time... so he/she finds it easy).
PS. I do no understand if I need to create jobControl/runningJobs... finishedJobs files. I think that'll be the next question...
any help is welcomed.
thanks
carlos.
galindolopez is offline   Reply With Quote
Old   April 5, 2005, 09:10
Default Looks like you don't have perm
Mattijs Janssens
mattijs is on a distinguished road
Looks like you don't have permission to write to the jobControl directory or to write the ns.ref file needed by FoamX.
Copy the .OpenFOAM-1.0.2 to your home directory instead and source ~/.OpenFOAM-1.0.2/cshrc instead.
After this check your
$FOAMX_USER_CONFIG
variable. It should now point to somewhere under
~/.OpenFOAM-1.0.2.
mattijs is offline   Reply With Quote
Running in patch when your license is running out Andrew CFX 2 August 9, 2007 13:48
Running a *.cas on many PC ? Cyril FLUENT 0 February 15, 2006 10:05
Running HPC Shazlan Siemens 1 April 8, 2005 13:34
Not running Mahbub Siemens 5 December 19, 2003 09:33
Anyone running under XP? Karl FLUENT 1 June 4, 2002 22:28
