April 27, 2009, 05:39 |
problem with use of opemfoam
Mohammed TOUIL
I am beginner and I need to use openfoam, but I did not know how and what the difference between the pre-processing , solving and post-processing?
thank for you |
April 27, 2009, 09:55 |
Gavin Tabor
Same as for any other CFD code. Pre-processing refers to the steps you take to set up the case you want to run; geometry and mesh generation, setting physical and numerical coefficients. Solving consists of actually running the code to generate numbers. Post-processing is manipulating those numbers to provide answers - this can involve graphical display (paraFoam) or data processing (eg. evaluating drag forces)
Gavin |
April 28, 2009, 03:19 |
Mohammed TOUIL
thanks Gavin
April 28, 2009, 03:21 |
Mohammed TOUIL
what's the best pre and post processing that is easy to handle
April 28, 2009, 03:38 |
Gijsbert Wierink
Rep Power: 18 |
For pre-processing there are many tools, it is a matter of taste and resources. You need to generate a mesh in some meshing program like Gambit (is expensive), Gridgen (also costs), Gmsh (is free, I believe), Salome (is free), Cubit (costs a bit), or some other program. For post-processing you can use ParaView as paraFoam or you can also do nice post-processing with Matlab. Of course, you can also use a more commercial post-processing program, but that costs.
Hope this informs you abit. Regards, Gijsbert |
April 30, 2009, 06:12 |
Wolfgang Heydlauff
Rep Power: 21 |
hi mtouil,
since i think you only want to use opensource (free) tools, i advice you to take the openfoam internal tool "blockMesh" for simple meshes (blocks, shapes, 2D, ...) and salome meca for more complex geometries (triangle, quads,...). gmsh is free an very simple, but only creates tetra-meshes. for CFD you might better use hexa-meshes. another pre-tool would be engrid from the company egits its for free and can also create structured boundary layers. also a good tool (but hard to learn) sit the openfoam internal program snappyhexmesh. it ca (with some errors and problems) create very complex meshes with a boundary layer added. see those many forum threads here. grtabor is right: paraVierw is a very nice and very good postprocessor. creating a 3D geometry would be your hardest part, if you don't have a CAD program. |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Incoherent problem table in hollow-fiber spinning | Gianni | FLUENT | 0 | April 5, 2008 10:33 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
