Boundary Conditions for Internal compressible Flow
Like Tree3Likes
Old   November 18, 2009, 06:33
Default Boundary Conditions for Internal compressible Flow
Carlos Xisto
xisto is on a distinguished road
Send a message via MSN to xisto
Hello all,
First of all i am a newbie in OpenFOAM
I' m trying to simulate a compressible flow in a duct with a bump using laminar rhoPisoFoam.
I used Fluent to verify the case. In Fluent i used for bc's Presure inlet (total pressure and tempreture) and pressure Outlet (static pressure).
Now i want to reply these bc's in Foam, but i dont no how.
I'am trying with these, please tell me if i'm rigth.
FOR PRESSURE:
internalField uniform 126453;
boundaryField
sidewalls
type zeroGradient;
up_wall
type zeroGradient;
low_wall
type zeroGradient;
inlet
type totalPressure;
p0 uniform 150000;
gamma 1.4;
value uniform 150000;
outlet
type fixedValue;
value uniform 126453;
FOR VELOCITY
internalField uniform (0 0 0);
boundaryField
sidewalls
type zeroGradient;
up_wall
type zeroGradient;
low_wall
type zeroGradient;
inlet
type zeroGradient;
outlet
type zeroGradient;
FOR TEMPERATURE
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
sidewalls
type zeroGradient;
up_wall
type zeroGradient;
low_wall
type zeroGradient;
inlet
type fixedValue;
value uniform 300;
outlet
type inletOutlet;
inletValue uniform 300;
Thanks in advance
CX
xisto is offline   Reply With Quote
Old   November 18, 2009, 06:36
Carlos Xisto
The controlDict file:
application rhoPisoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 2;
deltaT 0.00001;
writeControl runTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
adjustTimeStep no;
maxCo ;
maxDeltaT 1;
Old   November 21, 2009, 05:46
Carlos Xisto
Anyone???
CX
Old   December 3, 2009, 19:47
Carlos Xisto
Ok..
I used Total pressure for inlet with psi = psi (compressible flow).
For velocity at inlet i used presureDirectedVelocityInlet were i give a value for the inlet direction, and a value for intial velocity at the inlet.
I impose also total temprature..
For the outlet i specify a static pressure, and zeroGradient for all other variables.
Works fine..
Carlos Xisto
mm.abdollahzadeh likes this.
Old   January 30, 2010, 17:06
Mehmet Kaya
mhmt is on a distinguished road
Carlos, may I ask you to share your 0/ p U T files ?
Regards,
Mehmet
mhmt is offline   Reply With Quote
Old   January 30, 2010, 18:16
Carlos Xisto
These one are for the transonic case (works in the subsonic also).
For the supersonic you need to specify all variables at inlet (fixed values for temperature (static), pressure (static) and velocity). Extrapolate all variables from outlet (zero gradient).
Old   February 1, 2010, 07:24
Mehmet Kaya
Thanks for the files.
I will also simulate a transonic flow but with a steady solver (rhoSimpleFoam). Tried to copy your files.. but it is asking for U, phi for the total pressure inlet boundary and U,phi and psi for the total temperature inlet boundary. I tried also with the required information for U,psi and phi but unfortunately it is not working again.
Can I learn which version of Openfoam you are using?
Regards.
Old   February 1, 2010, 07:40
Carlos Xisto
Ok first of all I'm new at openFoam...
I'm using 1.6
Can you post the shell information here?
Cheers,
CX
Old   February 1, 2010, 09:01
Mehmet Kaya
Thanks for your quick answer Carlos.
I am using Openfoam 1.5 and here are my files ;
I also tried with the 1.6 version; then appears an error with the thermophysical properties. It crashes in a few iterations when I run laminar. I am sure that the problem is not the mesh, because I am just runnuing the code for a test case with a simple rectangular 2D geometry. Any comment is much appreciated..
Regards
Old   February 1, 2010, 10:23
Carlos Xisto
Ok.
I notice an error in your thermophysicalProperties dictionary.
You specify that you are using the Sutherland transport in the transport properties and then you input the values for the constTransport.
In the termophysical model you specify hThermo, I'm not familiarized with the 1.5, but in the 1.6 I used hPsiThermo - calculation based on h and psi. (I don't now if that patch even exist in the 1.5 version).
As you can see in my 0 files I don't need to specify phi and U. If you send me the error that appear in your shell. Maybe I can help... otherwise..
Cheers,
CX
Old   February 1, 2010, 11:48
Mehmet Kaya
As you have suggested, I used hPsiThermo model for the version 1.6.
thermoType hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>;
mixture air 1 28.9 1007 0 1.4792e-06 116;
Here is the error message.
Time = 0.5
smoothSolver: Solving for Ux, Initial residual = 0.232175, Final residual = 0.0183628, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.20495, Final residual = 0.0115015, No Iterations 6
DILUPBiCG: Solving for h, Initial residual = 0.304703, Final residual = 0.00124444, No Iterations 2
GAMG: Solving for p, Initial residual = 0.983346, Final residual = 7.43012e-09, No Iterations 15
time step continuity errors : sum local = 0.000107626, global = -5.18031e-05, cumulative = -5.20557e-05
rho max/min : 32.9887 1.27449
ExecutionTime = 12.9 s ClockTime = 13 s
Time = 0.6
smoothSolver: Solving for Ux, Initial residual = 0.283681, Final residual = 0.0173673, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.38148, Final residual = 0.0216, No Iterations 6
DILUPBiCG: Solving for h, Initial residual = 0.395197, Final residual = 0.0152132, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) in "/software/oss/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/software/oss/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::calculate() in "/software/oss/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#4 Foam::hPsiThermo<Foam:ureMixture<Foam::sutherlan dTransport<Foam::specieThermo<Foam::hConstThermo<F oam:erfectGas> > > > >::correct() in "/software/oss/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so"
#5 main in "/software/oss/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/rhoSimpleFoam"
#6 __libc_start_main in "/lib64/libc.so.6"
#7 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116
Floating point exception
Regards.
Old   February 1, 2010, 12:14
Carlos Xisto
Why do you use a deltaT=0.1 - the rhoSimpleFoam is a steady state solver.
Try deltaT=1..
CX
Old   February 1, 2010, 13:16
Mehmet Kaya
Changing the time step does not work unfortunately. I tried many variations for delta T.
With version 1.5, I have suceeded to run the code but the residuals are unacceptably big.
Time = 99
smoothSolver: Solving for Ux, Initial residual = 0.0108103, Final residual = 0.000975499, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0274258, Final residual = 0.00263698, No Iterations 2
DILUPBiCG: Solving for h, Initial residual = 0.0152814, Final residual = 0.000172995, No Iterations 1
GAMG: Solving for p, Initial residual = 0.733572, Final residual = 3.61836e-09, No Iterations 13
time step continuity errors : sum local = 9.54107e-08, global = 3.18967e-08, cumulative = 8.01901e-07
rho max/min : 1.67032 1.35875
smoothSolver: Solving for epsilon, Initial residual = 0.00824669, Final residual = 0.000471946, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0100756, Final residual = 0.000737614, No Iterations 2
Time = 100
smoothSolver: Solving for Ux, Initial residual = 0.0105662, Final residual = 0.00099737, No Iterations 4
smoothSolver: Solving for Uy, Initial residual = 0.0252288, Final residual = 0.000761451, No Iterations 4
DILUPBiCG: Solving for h, Initial residual = 0.0152109, Final residual = 0.000173026, No Iterations 1
GAMG: Solving for p, Initial residual = 0.735529, Final residual = 3.86563e-09, No Iterations 13
time step continuity errors : sum local = 1.02277e-07, global = 4.39179e-08, cumulative = 8.45819e-07
rho max/min : 1.66991 1.35852
smoothSolver: Solving for epsilon, Initial residual = 0.00844277, Final residual = 0.000502872, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.0101629, Final residual = 0.000767375, No Iterations 2
My BC should be allright because it is proved to be working on your case. I think I have a problem with the settings in fvSchemes. Increasing the number of correctors of the SIMPLE scheme is getting the residuals a bit lower, but not so much.
Regards
Old   February 1, 2010, 16:00
Carlos Xisto
the transonic case is a bit hard to solve.
In your fvSchemes you used for the divSchemes - upwind (in my case the residuals get stuck as well with the upwind)
Check mine:
With Gauss linear in the divSchemes works as well, but it perform better with the Gamma.
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss GammaV 1;
div(phid,p) Gauss Gamma 1;
div(phiU,p) Gauss Gamma 1;
div(phi,h) Gauss Gamma 1;
div(phi,k) Gauss Gamma 1;
div(phi,epsilon) Gauss Gamma 1;
div(phi,R) Gauss Gamma 1;
div(phi,omega) Gauss Gamma 1;
div((rho*R)) Gauss linear;
div(R) Gauss linear;
div(U) Gauss Gamma 1;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default none;
laplacian(muEff,U) Gauss linear corrected;
laplacian(mut,U) Gauss linear corrected;
laplacian(DkEff,k) Gauss linear corrected;
laplacian(DepsilonEff,epsilon) Gauss linear corrected;
laplacian(DREff,R) Gauss linear corrected;
laplacian(DomegaEff,omega) Gauss linear corrected;
laplacian((rho*(1|A(U))),p) Gauss linear corrected;
laplacian(alphaEff,h) Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
Old   February 4, 2010, 12:30
Mehmet Kaya
Hi Carlos.
Whatever I do, I could not get any reasonable results. I start thinking about that the rhoSimpleFoam solver may not be stable for transonic calculations. So, if you can e-mail me your own case, I would like to try it first with a transient solver (which is proved to be working) and than rhoSimpleFoam. If you can upload also the mesh, it would be better, so I can be sure that I am not doing any mistakes.
My e-mail:mehmetkaya84@gmail.com...Thanks for your efforts.
Regards.
Old   February 4, 2010, 16:22
Carlos Xisto
Ok Mehmet I will mail it to you.
But mine is a 3D inviscid Case.
Open the grid with ParaFoam, the direction of the flow is z.
And I used rhoPisoFoam works fine, check the results.
regards and best luck
CX
fumiya and lpz456 like this.
Old   February 18, 2010, 18:42
Default compressible flow
  #17
gaz
GHASSAN
gaz is on a distinguished road
Hi all
First of all I am a new user to ANSYS 12. I want to use fluent with compessible flow in side nozzle with heigh speed could you help me please.
Regards
Gaz
gaz is offline   Reply With Quote
Old   February 19, 2010, 10:59
Carlos Xisto
Hi gaz,
My advice is for you to try some of FLUENT tutorials available in the web.
Check this website.
http://courses.cit.cornell.edu/fluent/
Good Luck
CX
PS: This is a forum reserved for openFoam, if you have more doubts check the FLUENT forum.
Old   November 27, 2012, 07:54
Default Need help
  #19
Valentin Wibaut
vwibaut is on a distinguished road
Hi all
I would like to simulate a supersonic nozzle with and without shock. So I have the same boundary conditions of Xisto except for the pressure at the outlet. I use waveTransmissive to avoid the reflection of the wave.
Is it ok?
Other question: When I use waveTransmissive I have to choose a "linf". But how do I choose the value?
vwibaut is offline   Reply With Quote
Old   February 27, 2013, 12:24
immortality's Avatar
Ehsan
immortality is on a distinguished road
what George?
what schemes there are for div(U)?
immortality is offline   Reply With Quote
Help needed with laminar couette flow boundary conditions bengt OpenFOAM Running, Solving & CFD 0 March 19, 2009 08:25
boundary conditions for boundary layer flow A. Al-zoubi CFX 0 November 3, 2007 07:11
compressible flow boundary conditions yangqing FLUENT 2 January 22, 2002 10:19
