March 29, 2018, 06:04 |
Convergence of Pressure in MPPICFoam
SURAJ
Rep Power: 8 |
My solver Pressure residual is not getting converged event after 100000 iterations,The value of residual remains between 0.1 and 1.0 . And I want it in below 0.001 atleast.What could be the possible reasons.
What changes should I do. I am using MPPICFoam . my details of setting file is as below- Please suggest me chages,I tried with changing Mesh size.deltaT but unable to get.My solver is working very slow. BlockMeshDict- -------------------------------------------------------------------- // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (0 0 0) //0 (0.05 0 0) //1 (0.05 0.0001 0) //2 (0 0.0001 0) //3 (0 0 2.79) //4 (0.05 0 2.79) // 5 (0.05 0.0001 2.79) //6 (0 0.0001 2.79) //7 ); blocks ( hex (0 1 2 3 4 5 6 7) (50 3 1200) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type patch; faces ((4 5 6 7)); } bottom { type patch; faces ((0 1 2 3)); } walls { type wall; faces ( (1 2 6 5) (3 0 4 7) ); } front { type cyclic; neighbourPatch back; faces ((0 1 5 4)); } back { type cyclic; neighbourPatch front; faces ((2 3 7 6)); } ); mergePatchPairs ( ); // ************************************************** *********************** // ControlDict // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application MPPICFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 100; deltaT 2e-4; writeControl adjustableRunTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; functions { fieldAverage1 { type fieldAverage; functionObjectLibs ( "libfieldFunctionObjects.so" ); resetOnRestart false; outputControl outputTime;//runTime;//timeStep; //writeInterval 0.05; timeStart 10.0; //timeEnd 0.5; resetOnOutput false; fields ( U.air { mean on; prime2Mean off; base time; } alpha.air { mean on; prime2Mean off; base time; } p { mean on; prime2Mean off; base time; } ); } } // ************************************************** *********************** // Fvschemes // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default CrankNicolson 0.8; } gradSchemes { default Gauss linear; } divSchemes { default none; div(alphaPhic,U.air) Gauss linearUpwindV unlimited; div(((alpha.air*nuEff.air)*dev2(T(grad(U.air))))) Gauss linear; div(phiGByA,kinematicCloud:alpha) Gauss linear; div(alphaPhic,epsilon.air) Gauss limitedLinear 1; div(alphaPhic,k.air) Gauss limitedLinear 1; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************** *********************** // fvSolutions- // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-06; relTol 0.01; smoother GaussSeidel; } pFinal { solver GAMG; tolerance 1e-06; relTol 0; smoother GaussSeidel; } "(U|k|epsilon|omega).air" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } "(U|k|epsilon|omega).airFinal" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0.1; } kinematicCloud:alpha { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } } PIMPLE { nOuterCorrectors 1; nCorrectors 2; momentumPredictor yes; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } relaxationFactors { equations { ".*" 0.7; } } // ************************************************** *********************** // |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
"Pressure Inlet" Boundary Setup | Wijaya | FLUENT | 15 | May 18, 2016 10:08 |
Pressure convergence - Epsi vs Resi | Akshay | FLOW-3D | 4 | August 14, 2014 00:18 |
Pressure Drop Convergence Study | Inconel | OpenFOAM Pre-Processing | 0 | May 30, 2013 06:06 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
