August 29, 2019, 23:55 |
Problem using paraFoam with cyclicAMI
Rep Power: 12 |
Dear all,
I generated a mesh using blockMesh and created cyclicAMI boundaries. The process of creating cyclicAMI seems fine. The results is Code:
Create polyMesh for time = 0 Reading createPatchDict Adding new patch left as patch 6 from { type cyclicAMI; neighbourPatch right; transform translational; separationVector ( 0 1 0 ); matchTolerance 1e-06; } Adding new patch right as patch 7 from { type cyclicAMI; neighbourPatch left; transform translational; separationVector ( 0 -1 0 ); matchTolerance 1e-06; } Moving faces from patch left1 to patch 6 Moving faces from patch right1 to patch 7 Doing topology modification to order faces. Not synchronising points. Removing patches with no faces in them. Removing zero-sized patch left1 type patch at position 1 Removing zero-sized patch right1 type patch at position 2 Removing patches. Writing repatched mesh to 0 End Code:
AMI: Creating addressing and weights between 3600 source faces and 3600 target faces --> FOAM Warning : From function void Foam::AMIMethod<SourcePatch, TargetPatch>::checkPatches() const [with SourcePatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>; TargetPatch = Foam::PrimitivePatch<Foam::face, Foam::SubList, const Foam::Field<Foam::Vector<double> >&>] in file lnInclude/AMIMethod.C at line 57 Source and target patch bounding boxes are not similar source box span : (1.6 3.33067e-16 0.9) target box span : (1.6 3.33067e-16 0.9) source box : (-0.4 -1 0) (1.2 -1 0.9) target box : (-0.4 -1.11022e-16 0) (1.2 2.22045e-16 0.9) inflated target box : (-0.491788 -0.0917878 -0.0917878) (1.29179 0.0917878 0.991788) --> FOAM FATAL ERROR: Unable to find initial target face Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (-4 -10 0) //vertex 0 (12 -10 0) //vertex 1 (12 10 0) //vertex 2 (-4 10 0) //vertex 3 (-4 -10 9) //vertex 5 (12 -10 9) //vertex 6 (12 10 9) //vertex 7 (-4 10 9) //vertex 8 ); blocks ( hex (0 1 2 3 4 5 6 7) (80 100 45) simpleGrading (1 1 1) ); edges ( ); boundary ( walls { type wall; faces ( (0 1 2 3) ); } left1 { //type cyclic; //neighbourPatch right; type patch; faces ( (0 1 5 4) ); } right1 { //type cyclic; //neighbourPatch left; type patch; faces ( (3 2 6 7) ); } inlet { type patch; faces ( (0 3 7 4) ); } outlet { type patch; faces ( (1 2 6 5) ); } top { type patch; faces ( (4 5 6 7) ); } ); Code:
FoamFile { version 2.0; format ascii; class dictionary; object createPatchDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // pointSync false; patches ( { name left; patchInfo { type cyclicAMI; neighbourPatch right; transform translational; separationVector (0 1 0); matchTolerance 1e-6; } constructFrom patches; patches (left1); } { name right; patchInfo { type cyclicAMI; neighbourPatch left; transform translational; separationVector (0 -1 0); matchTolerance 1e-6; } constructFrom patches; patches (right1); } ); Code:
vertices ( (-4 -5 0) //vertex 0 (12 -5 0) //vertex 1 (12 5 0) //vertex 2 (-4 5 0) //vertex 3 (-4 -5 9) //vertex 5 (12 -5 9) //vertex 6 (12 5 9) //vertex 7 (-4 5 9) //vertex 8 ); blocks ( hex (0 1 2 3 4 5 6 7) (80 50 45) simpleGrading (1 1 1) ); Does anyone have any ideas about this problem? Best regards, Leo |
September 1, 2019, 22:06 |
Rep Power: 12 |
For anyone who is interested.
The " separationVector" should be (0 2 0) and (0 -2 0) for left and right respectively. The vector is not normalized, i.e. ||v||=1. The length of the vector should be the distance between two planes. |
[OpenFOAM] Visualization problem on ParaFoam | Rider | ParaView | 10 | June 27, 2016 10:19 |
cyclicAMI problem in MRF zone | jmf | OpenFOAM Running, Solving & CFD | 8 | August 14, 2014 13:48 |
Graphics problem in ParaFoam | Tarak | OpenFOAM | 0 | October 28, 2010 19:10 |
[OpenFOAM] paraFoam problem | autumn1012 | ParaView | 22 | July 8, 2010 02:20 |
[blockMesh] Problem using paraFoam to view cavityGrade mesh file | felik9 | OpenFOAM Meshing & Mesh Conversion | 1 | September 27, 2009 15:31 |
