Fixed Outlet Mass Flux boundary condition?
Like Tree1Likes
  • 1 Post By herbert
Old   June 30, 2010, 03:52
Default Fixed Outlet Mass Flux boundary condition?
trex930 is on a distinguished road
Hi!
I read somewhere that Outlet Mass Flux boundary conditions are being discussed in this form... but i did many searches and couldnt find anything.
Basically my question is
Is it possible to set the mass flux at the outlet? If so, what boundary condtions do i have to call??
ie. type FixedOutletMassFlux: ?? (does this exist)
Thanks in advance Foamers!
Cheers,
T
trex930 is offline   Reply With Quote
Old   June 30, 2010, 07:37
Stefan Herbert
herbert is on a distinguished road
try flowRateInletVelocity with a negative flowRate. I have never used it this way, but it should work though.
Regards,
Stefan
mm.abdollahzadeh likes this.
herbert is offline   Reply With Quote
Old   June 30, 2010, 21:44
Hi Herbert,
I have indeed tried flowRateVelocityInlet but to no success. Any other options. I am unclear as to why its not working, but it seems that when the inlet velocity goes from positive to negative, the flow direction is still the same... which completely does not makesense to me! and then when it hits 0, a whole pile of errors come up. And as we all know, debugging openFoam errors are next to impossible.
Is it possible to just set the outlet velocity whilst leaving the inlet velocity as an $internalField? I have tried setting outlet velocity but it doesnt seem to work. Is there a different boundary condition that I should be using?
Cheers,
T
Variable names for mass flux for a recirculating-outlet boundary condition BRNN Fluent UDF and Scheme Programming 7 September 4, 2018 13:49
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
outlet boundary condition for compressor modeling siamak1424 FLUENT 3 August 8, 2009 05:55
Mass flow boundary condition Renato. Main CFD Forum 0 July 21, 2006 22:07
Mass flow boundary condition vivian Main CFD Forum 0 April 10, 2006 23:32
