[swak4Foam] funkySetFields - not recognizing turbulent wall BC
Old   January 6, 2011, 12:17
Default funkySetFields - not recognizing turbulent wall BC
Goncalo Pedro
gonpe is on a distinguished road
Hi All
Trying to run a funkySetFields (FSF) on the epsilon variable on one of the tutorials. The FSF utility is not finding the turbulent wall bc (in this case for epsilon). Any thoughts. Below is the output.
|  \\    /   O peration     | Version:  1.7.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : 1.7.x-b32f406e2652
Exec   : funkySetFields -keepPatches -field epsilon -time 0 -expression 0.134799/(dist()+0.010000)
Date   : Jan 06 2011
Time   : 12:10:41
Host   : ubu1
PID    : 27303
Case   : pitzDaily
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Time = 0
 Using command-line options
 Putting "0.134799/(dist()+0.010000)" into field epsilon at t = "0" if condition "true" is true
 Keeping patches unaltered
--> FOAM FATAL IO ERROR:
Unknown patchField type epsilonWallFunction for patch type wall
Valid patchField types are :
42
advective
buoyantPressure
calculated
cyclic
directMapped
directionMixed
empty
fan
fixedFluxPressure
fixedGradient
fixedInternalValue
fixedPressureCompressibleDensity
fixedValue
freestream
freestreamPressure
inletOutlet
inletOutletTotalTemperature
mixed
oscillatingFixedValue
outletInlet
outletMappedUniformInlet
partialSlip
processor
rotatingTotalPressure
sliced
slip
symmetryPlane
syringePressure
timeVaryingMappedFixedValue
timeVaryingMappedTotalPressure
timeVaryingTotalPressure
timeVaryingUniformFixedValue
timeVaryingUniformInletOutlet
totalPressure
totalTemperature
turbulentInlet
turbulentIntensityKineticEnergyInlet
uniformDensityHydrostaticPressure
uniformFixedValue
waveTransmissive
wedge
zeroGradient
file: /projects/ubu1/09-40322-Makkah/ExternalFlow/Runs/pitzDaily/0/epsilon::boundaryField::upperWall from line 35 to line 36.
    From function fvPatchField<Type>::New(const fvPatch&, const DimensionedField<Type, volMesh>&, const dictionary&)
    in file /software/OpenFOAM/OpenFOAM-1.7.x/src/finiteVolume/lnInclude/newFvPatchField.C at line 110.
FOAM exiting
gonpe is offline   Reply With Quote
Old   January 10, 2011, 05:16
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by gonpe View Post
Hi All
That boundary condition is either located in libcompressibleRASModels.so or libincompressibleRASModels.so (depending on what kind of case this is) and FSF doesn't link these. The solution is to force the loading of that library. You do that by adding
libs ( "libcompressibleRASModels.so" );
to the system/controlDict (add an "in" in the right place if your case is incompressible).
If this works for you, then it would be nice if you added a remark to the regular FSF-Wiki-page so that future generations will profit from that knowledge
Bernhard
gschaider is offline   Reply With Quote
Old   January 10, 2011, 10:30
Goncalo Pedro
That worked ... thanks for your help.
I will post to the Wiki.
Goncalo
swak4foam error
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
SolidWorks Flow Simulation for turbulent wall bounded flow Dominique FloEFD, FloWorks & FloTHERM 4 May 7, 2015 06:48
How to define the turbulent k near the wall ? joy2000 Fluent UDF and Scheme Programming 2 May 13, 2013 22:54
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh Shoonya OpenFOAM Meshing & Mesh Conversion 11 January 20, 2012 06:23
