implementation of mapFields into parallel transient case
Old   May 30, 2012, 08:16
Default implementation of mapFields into parallel transient case
Simon Arne
simpomann is on a distinguished road
Hey,
I calculate a flow around an object, based on the motorBike tutorial.
A steady-state case is set up, that creates a directory at timestep 50 that i want to implement into my transient case. The snappyHexMesh options are the same for both.
Unluckily i am not sure how i can implement the mapFields function into my transient-Allrun.
My steady-state Allrun (solver is SIMPLE, results look allright)
#!/bin/sh
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
cp system/fvSolution.OF2.1.0 system/fvSolution
cp system/fvSchemes.OF2.1.0 system/fvSchemes
cp 0.org/nut.OF2.1.0 0.org/nut
cp constant/polyMesh/blockMeshDict.OF2.1.0 constant/polyMesh/blockMeshDict
cp -r 0.org 0 > /dev/null 2>&1
runApplication blockMesh
runApplication snappyHexMesh -overwrite
runApplication decomposePar
runParallel renumberMesh 6 -overwrite
runParallel potentialFoam 6 -initialiseUBCs -noFunctionObjects
runParallel `getApplication` 6
runApplication reconstructPar -time 50
My transient-case Allrun: (solver is PIMPLE)
#!/bin/sh
mapFields /home/simon/openFoam/nachstellen/startwerte/ -sourceTime 50 -consistent
runApplication reconstructParMesh -constant -mergeTol 1e-6
During the mapping process no error appears in the terminal window. All log files seem okay except for the pimple log!
And this is my PIMPLE log:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : pimpleFoam -parallel
Date   : May 30 2012
Time   : 13:57:50
Host   : "simon-desktop"
PID    : 5693
Case   : /home/simon/openFoam/nachstellen/parallel
nProcs : 6
Slaves :
5
"simon-desktop.5694"
"simon-desktop.5695"
"simon-desktop.5696"
"simon-desktop.5697"
"simon-desktop.5698"
Pstream initialized with:
    floatTransfer     : 0
    nProcsSimpleSum   : 0
    commsType         : nonBlocking
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model SpalartAllmarasDDES
No field sources present
PIMPLE: Operating solver in PISO mode
Starting time loop
Courant Number mean: 0.135977 max: 5.28681
Time = 0.001
DILUPBiCG:  Solving for Ux, Initial residual = 0.00271502, Final residual = 2.0949e-06, No Iterations 5
DILUPBiCG:  Solving for Uy, Initial residual = 0.00274523, Final residual = 4.48912e-06, No Iterations 4
DILUPBiCG:  Solving for Uz, Initial residual = 0.00143448, Final residual = 5.34199e-06, No Iterations 4
GAMG:  Solving for p, Initial residual = 0.294934, Final residual = 0.00136378, No Iterations 4
time step continuity errors : sum local = 6.86498e-08, global = -3.4579e-09, cumulative = -3.4579e-09
GAMG:  Solving for p, Initial residual = 0.0391325, Final residual = 8.14741e-07, No Iterations 16
time step continuity errors : sum local = 4.55977e-11, global = -2.81814e-12, cumulative = -3.46072e-09
[1] [5] #0  Foam::error::printStack(Foam::Ostream&)[3] [4] #0[0]   Foam::error::printStack(Foam::Ostream&)[2] #0  Foam::error::printStack(Foam::Ostream&)#0  Foam::error::printStack(Foam::Ostream&)##0  Foam::error::printStack(Foam::Ostream&)0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[5] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[4] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[1] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[3] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[0] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[1] #2  Uninterpreted:
[1] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[4] #2  Uninterpreted:
[4] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[2] #2  Uninterpreted:
[2] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[5] #2  Uninterpreted:
[5] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[1] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[3] #2  Uninterpreted:
[3] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[4] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[2] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[0] #2  Uninterpreted:
[0] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[3] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[0] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[1] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[4] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[2] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
[5] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[4] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[3] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[2] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[0] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
[5] #5  Foam::fvMatrix<double>::solve() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[3] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[4] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[5] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[1] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so"
[0] #6  Foam::incompressible::LESModels::SpalartAllmaras::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[3] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[2] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[1] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[5] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[0] #7  Foam::incompressible::LESModel::correct() in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[2] #8   in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[4] #8   in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[1] #8   in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[0] #8   in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[3] #8   in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so"
[5] #8
[4]  in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pimpleFoam"
[4] #9  __libc_start_main
[2]  in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pimpleFoam"
[2] #9  __libc_start_main[0]  in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pimpleFoam"
[0] #9  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
[4] #10  [1]  in [3]  in "/opt/openf"/opt/openfoam210/platfooam210/platforms/linuxGccDPOpt/bin/pimpleFoam"
[1] #9  [3] #9  __libc_start_main__libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
[0] #10
[5]  in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/pimpleFoam"
[5] #9  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
[2] #10   in "/lib/tls/i686/cmov/libc.so.6"
[1] #10   in "/lib/tls/i686/cmov/libc.so.6"
[5] #10
[simon-desktop:05697] *** Process received signal ***
[simon-desktop:05697] Signal: Floating point exception (8)
[simon-desktop:05697] Signal code:  (-6)
[simon-desktop:05697] Failing at address: 0x1641
[simon-desktop:05697] [ 0] [0xb777e410]
[simon-desktop:05697] [ 1] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6sigFpe10sigHandlerEi+0x61) [0xb6055ea1]
[simon-desktop:05697] [ 2] [0xb777e400]
[simon-desktop:05697] [ 3] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x165) [0xb69c3f45]
[simon-desktop:05697] [ 4] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam8fvMatrixIdE5solveEv+0xe5) [0xb74a5e45]
[simon-desktop:05697] [ 5] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompressible9LESModels15SpalartAllmaras7correctERKNS_3tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEEEE+0xa6b) [0xb73003eb]
[simon-desktop:05697] [ 6] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel7correctEv+0x44) [0xb72ae724]
[simon-desktop:05697] [ 7] pimpleFoam() [0x805f34e]
[simon-desktop:05697] [ 8] /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6) [0xb59a9bd6]
[simon-desktop:05697] [ 9] pimpleFoam() [0x805bee1]
[simon-desktop:05697] *** End of error message ***
[3] #10
[simon-desktop:05693] *** Process received signal ***
[simon-desktop:05693] Signal: Floating point exception (8)
[simon-desktop:05693] Signal code:  (-6)
[simon-desktop:05693] Failing at address: 0x163d
[simon-desktop:05693] [ 0] [0xb7737410]
[simon-desktop:05693] [ 1] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so(_ZN4Foam6sigFpe10sigHandlerEi+0x61) [0xb600eea1]
[simon-desktop:05693] [ 2] [0xb7737400]
[simon-desktop:05693] [ 3] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x165) [0xb697cf45]
[simon-desktop:05693] [ 4] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleRASModels.so(_ZN4Foam8fvMatrixIdE5solveEv+0xe5) [0xb745ee45]
[simon-desktop:05693] [ 5] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompressible9LESModels15SpalartAllmaras7correctERKNS_3tmpINS_14GeometricFieldINS_6TensorIdEENS_12fvPatchFieldENS_7volMeshEEEEE+0xa6b) [0xb72b93eb]
[simon-desktop:05693] [ 6] /opt/openfoam210/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so(_ZN4Foam14incompressible8LESModel7correctEv+0x44) [0xb7267724]
[simon-desktop:05693] [ 7] pimpleFoam() [0x805f34e]
[simon-desktop:05693] [ 8] /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe6) [0xb5962bd6]
[simon-desktop:05693] [ 9] pimpleFoam() [0x805bee1]
[simon-desktop:05693] *** End of error message ***
mpirun noticed that process rank 4 with PID 5697 on node simon-desktop exited on signal 8 (Floating point exception).
Without the mapFields, my case should work. For sure it does without parallel-settings and map-fields.
Big thanks in advance, i am new to this programme (got started 1 month ago) and completely lost. I will give all necessary information, please help me!
I am completely unsure about how to implement parallelization and mapping correctly. I reconstruct time 50 in my steady-state case because mapFields with -sourceParallel doesn't work at all.
I want the transient-case to take the fields from my steady-state case as initial conditions. Am I on the right track?
Best regards,
Simon
simpomann is offline   Reply With Quote
Old   June 1, 2012, 02:47
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
Hi Simon,
there's this: "Courant Number mean: 0.135977 max: 5.28681"
It seems a little high. Try to start with a smaller initial timestep. I guess you started with DeltaT = 0.001 ... so try 0.0001 or even lower.
What about MeshQuality, have you checked?
Greets Jan
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   June 1, 2012, 13:13
Simon Arne
Hey,
Thanks for your advice! I added
"adjustTimeStep yes;
maxCo 1.0;
to my transient case Allrun and now the solver is working.
Good success.
Unluckily the mapping still doesn't work.
The message appearing within the terminal window:
Exec   : mapFields /home/simon/openFoam/longterm/startwerte -consistent -parallelSource
Date   : Jun 01 2012
Time   : 19:04:02
PID    : 2038
Case   : /home/simon/openFoam/longterm/parallel
nProcs : 1
Source: "/home/simon/openFoam/longterm" "startwerte"
Target: "/home/simon/openFoam/longterm" "parallel"
Create databases as time
Create target mesh
Target mesh size: 1253378
Source processor 0
Source time: 0
Target time: 0
mesh size: 417792
--> FOAM Warning :
    From function meshToMesh::calcAddressing()
    in file meshToMeshInterpolation/meshToMesh/calculateMeshToMeshAddressing.C at line 156
    Source patch inlet has no faces. Not performing mapping for it.
Mapping fields for time 0
    interpolating ccz
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigSegv::sigHandler(int) in "/opt/openfoam210/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
 in "/opt/openfoam210/platforms/linuxGccDPOpt/bin/mapFields"
#8  __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
Segmentation fault
How can I implement the mapping?
Old   September 3, 2012, 11:33
Sebastian Bomberg
sebas is on a distinguished road
Hey simon!
sorry for the lag but I'm quite new to the forum.
It looks like mapFields wants to map the stuff in the "0" time folder (which is not reconstructed). That's why it complains about the empty patch.
You should change your startTime in your target controlDict to 50 and/or maybe create a folder for time "50" as well.
Hope that helps.
B.T.W. it should work without reconstructing to if you give it the options -parallelSource (and -parallelTarget)
sebas is offline   Reply With Quote
Old   August 2, 2016, 04:41
yb8119 is on a distinguished road
Hi sebas!
I got the same problem as described in the post, and I tried your method which is to reconstruct the source case.
Then the warnings did disappeared, however, nothing was written into processor folders.
The command I used is
mapFields ../test_parallel -parallelTarget -consistent
the output in the terminal looked like:
Create source mesh
Source time: 2.5
Target time: 2.5
Source mesh size: 1600
Target processor 0
mesh size: 1016
Mapping fields for time 2.5
Target processor 1
mesh size: 584
Do you have any idea why this happens?
Thanks in advance!
yb8119 is offline   Reply With Quote
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM Bugs 17 April 28, 2013 23:44
Global residuals in transient case mx Main CFD Forum 0 August 6, 2007 07:12
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Fluidisation transient case Vikas Kumar Main CFD Forum 0 April 24, 2003 03:29
UDFs Parallel Implementation Rules Greg Perkins FLUENT 0 February 4, 2001 05:59
