November 8, 2011, 10:55 |
Units question
Humberto
Rep Power: 14 |
Hello everybody, I am using pisoFoam to run an external flow over an obstacle, I can not understand the units field in the tutorials where p has dimensions of [0 2 -2 0 0 0 0] instead of what I would expect [1 -1 -2 0 0 0 0].
can anybody point me in the right direction? Thanks. |
November 8, 2011, 11:03 |
Bernhard
Rep Power: 21 |
The equations are solved for p/rho, so that rho only appears in the kinematic viscosity. This explains the different units.
November 8, 2011, 11:08 |
Humberto
Rep Power: 14 |
Thanks for replying so fast Bernhard,
so the results I get for pressure need to be multiplied by rho to make them Pascals? żdoes it make a difference if I declare units of [1 -1 -2 0 0 0 0] ? |
November 8, 2011, 11:10 |
Bernhard
Rep Power: 21 |
Yes, then they will be pascals, but be certain from the source code if it is indeed the kind of pressure you think it is.
If you change the units, the dimensions for the different terms are inconsistent. This will throw you a fatal error. |
units |
Display Modes | |
question about uds | tanven | FLUENT | 2 | July 5, 2015 11:22 |
units in OpenFOAM | megacrout | OpenFOAM | 4 | July 19, 2011 08:04 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
