October 25, 2011, 11:29 |
Geometry and mesh generation in OpenFoam
Hello!
In new in the openfoam world. So far, i just solved the tutorials of the user guide. My main contact with the CFD world is with ansys, Fluent and CFX. When using ansys, i used to generate the geometry in CAD software (PRO-E or Solid Works) and then import this from ansys to mesh it. What is the best path in openfoam to generate and to mesh complex geometries with open source code? I have done some research and found that salome is good tool to do the pre-processing work, but, does it work with openfoam? Or maybe is better to work with comercial cad software and then export to a mesh software? I am trying to stablish a simulation enviroment based completely on open source code. I would like to read your sugestions about this subject. Thanks! |
October 28, 2011, 21:40 |
Salome work
Wesley T.
Rep Power: 17 |
Yes, Salome works well. The CAELinux distribution at least used to have tutorials showing how to work that program with OpenFOAM.
The only issue I have had with Salome is as a get into generating more complex geometries, the program sometimes creates "non-valid" shapes - shapes it can't use to cut other shapes or can't mesh. My personal problem is trying to create a helical screw (take a cylinder and cut out a helix with a circular cross-section). I have not been able to solve that geometry. Wes |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
