Modelling wave impacts on offshore simple structure |
January 12, 2012, 03:43 |
Hugh Fell
Hi there,
This is my first post so let me know if there is any more information that I need to let you know. I'll start by saying that I am completely new to modelling so please excuse my lack of knowledge in this field. I am currently trying to model un-extreme wave impacts on offshore structures using fluid dynamic equations. I am not really sure what kind of variation on linear wave theory I should be using. Any suggestions would be much appreciated. Thanks Hugh |
January 13, 2012, 10:31 |
#2 | |
Bo Terp Paulsen
When it comes to modelling free surface flows in OpenFoam I would strongly suggest you have look at the waves2Foam utility http://openfoamwiki.net/index.php/Contrib/waves2Foam . I have had great success using the utility for calculating hydrodynamic forces on a circular cylinder from both stream function waves and fully nonlinear irregular waves. The utility comes with at wide range of wave theories; so, have a look at the possibilities and choose the one that suits your application best. Good luck! Best regards, Bo Terp |
May 2, 2012, 06:16 |
Albert Tong
Hi Bo Terp,
Thanks for your explanation. As for the streamFunction wave theory, is it right that the matlab code ( located at /wave2Foam/application/utilities/misc/matlab/generateStreamFile.m ) should be run to get the required wave coefficients to be filled in waveProperties file? If it is yes, then should I specify wave height H, water depth h and other parameters in generateStreamFile.m? Thanks again.
Kind regards, Albert |
May 2, 2012, 07:56 |
#4 | |
Bo Terp Paulsen
Good luck, Bo Terp |
May 4, 2012, 11:47 |
Albert Tong
Hi Bo Terp,
Would you care to elaborate on EorS and uEorS? I cannot figure out what does that do in the code. Also, is it possible to make "David R. Fuhrman's lecture notes from course 'Linear and non-linear wave theory' given at TUD" public if you have? Cheers.
May 7, 2012, 04:49 |
#6 | |
Bo Terp Paulsen
A second type of mean fluid speed is the depth-integrated mean speed of the fluid under the wave in a Lagrangian frame of reference. This definition of the mean fluid speed is related to Stokes's second approximation to the wave speed and is equivalent to defining the mean 'mass-transport velocity' or the Stokes drift. Normally this velocity is defied as u_2 or u_S. In the Matlab script EorS is a string acting as a boolean indicating however the mean Eulerian fluid velocity or the Stokes drift is defined. uEorS is a scalar indicating the velocity in the given frame of reference. I do not have the lecture noted by David Fuhrman at hand, but for further reading have a look at the classic paper by J. D. Fenton "The Numerical Solution Of Steady Water Wave Problems", 1988, Computers & Geosciences. Best regards, Bo Terp |
linear wave theory, off-shore modelling, wave generation |
Thermal modelling of a ship structure using ANSYS | chetanladha | ANSYS | 2 | April 14, 2011 16:25 |
How to do thermal and flow modelling in honeycomb structure | senCFX | Main CFD Forum | 0 | January 25, 2011 17:07 |
MOdelling a 3-D structure of a fan blade using NACA airfoils | ashu.feb28 | Main CFD Forum | 0 | February 2, 2010 11:19 |
Simple structure & fluid interaction | Bren | Main CFD Forum | 13 | August 10, 2007 15:22 |
Wave structure interaction | R.Balaji | Main CFD Forum | 0 | March 17, 2002 12:56 |
