inverse of a matrix or solution of implicit equation
Like Tree2Likes
  • 2 Post By romant
Old   April 25, 2012, 08:51
Default inverse of a matrix or solution of implicit equation
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
I am looking for a way to solve the following equation
a_i = c1 * a_j * du_i / dx_j + c2
for i=1 this looks like
a_1 = c1 * a_1 * du_1/dx_1 + c1 * a_2 * du_1 / dx_2 + c1 * a_3 * du_1 / dx_3 + c2
where a is a vector, u is a vector and i and j run from 1-3. This can be solved by either matrix inversion where A_ij = (I- (c * du_i / dx_j)) is the coefficient matrix in every cell (I is the identity matrix).
The idea is to rewrite this into an explicit form, by taking a_1 to the other side.
I was also looking into a form to solve this with the build in fvMatrix of OF, unfortunately you can basically only insert div, grad (or other derivative forms) and source. However, source (fvm::Sp(scalar, solvableVariable))cannot take a tensor as it would be required from du_i/dx_j as a multiplication factor for vector a
The other idea is to take the coefficient matrix (A_ij) in every cell and divide the right hand side by this.
A_ij*a_j = S_i => a_j = A_ij^-1 * S_i
Does anybody know how to do this in OF?
OpenFOAM version used is 2.1.
~roman
romant is offline   Reply With Quote
Old   April 25, 2012, 10:35
romant's Avatar
Roman Thiele
Further checking this, I found a function inv(const tensorField&), which I believe takes the inverse of a tensor, but I am unsure for what it takes the inverse, either the tensor in every cell or the overall tensor (the field itself).
I now assumed that it takes the inverse of every tensor in the cells and the following code came out for the following equation
(I-A_ij) * a_j = S_i
-> a_j = (I-A_ij)^1 * S_i
        // velocity gradient matrix, M_ij
      const volTensorField coeffMatrix(-sThetauCoeff*Cthetau2*fvc::grad(U));
        // I_ij - M_ij
      const volTensorField negCoeffMatrix(I-coeffMatrix);
        // (I_ij - M_ij)^1
      const volTensorField invNegCoeffMatrix(inv(negCoeffMatrix));
      thetau = invNegCoeffMatrix & (gSource+gradTSource);
~roman
Old   April 27, 2012, 05:21
Default solution found
romant's Avatar
Roman Thiele
The solution was a little bit easier than first assumed. OpenFOAM has a great operator definition which lets you divide by a tensor
So in case you have an equation
A_ij x_j = s_i
and you want to solve for x_j, where A is a second order tensor (for example the gradient of velocity, grad(U) ) and x and s are vectors, the one simply divides by A_ij
as in
  volVectorField s(g);  // g is the gravity field
  volTensorField A(fvc::grad(U));
  volVectorField x = s / A;
I guess you could do the same with
 volTensorField invA(inv(A));  // taking the inverse of A
 volVectorField x = (1/det(A)*invA) & s; // det(A) takes the determinant
the previous solution is of course much simpler and more elegant
Tushar@cfd and huangxianbei like this.
~roman
Old   August 6, 2013, 08:02
Hossein
atoof is on a distinguished road
Send a message via Yahoo to atoof
Dear Roman,
I need to calculate a vector using anothor vector and a matrix by formula:
a=[X^T X]^-1 X^T y,
where y is a vector and X is a square matrix (T means transpose and -1 means inverse of a matrix), but the matrix and vectors are not volScalarField.
Is there any possible to do that by openFOAM?
Regards,
atoof is offline   Reply With Quote
Old   August 6, 2013, 09:02
romant's Avatar
Roman Thiele
Originally Posted by atoof View Post
Dear Roman,
a=[X^T X]^-1 X^T y,
Regards,
X should be a volTensorField I think and then y is a volVectorField, there is an operator for transpose, which is X.T() for a tensor X, so an inverse (^1) you get with inv(X) and a transpose with X.T()
~roman
error message cuteapathy CFX 14 March 20, 2012 06:45
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Exact solution of Buckley_Leveret equation mcaro Main CFD Forum 0 January 25, 2011 06:52
Iterative solution to Poissons Equation Phiper Main CFD Forum 4 December 10, 2010 01:58
Conceptual trouble--please help me understand what my matrix solution is telling me bzz77 Main CFD Forum 0 March 25, 2010 16:31
