May 15, 2012, 14:37 |
modifing equations in the solver
Hello
Ive a question about the non-linear term (convection term) in N.S equations : (u*nabla)u I want to modify this term into : ((u+u0)*nabla)(u+u0) I mean u=u+u0 where u0 is defind as some known function , can someone please give me a direction on how to do this? ThankYou |
May 16, 2012, 01:50 |
Bernhard
Rep Power: 21 |
Did you derive what the discretized equation should look like? Maybe you can treat all the terms that are not u*nabla u as a source?
By the way, what is the physics in this approach? It seems a bit weird here? Maybe you want to use u0 as initialization? |
May 16, 2012, 08:12 |
This form of equation represent the nonlinear dynamics of the perturbations only and u0 is the basic flow, so u is vector of perturbations and p is the fluctuated pressure only. in the convective term
((u+u0)*nabla)(u+u0): (u0*nabla)u0 is identically zero and the basic pressure plus the laplace term for u0 constitute the basic velocity u0, so also these terms falls , and then you get the dynamics of the perturbations Thanks for the advice I will try to understand your suggestion |
May 16, 2012, 08:34 |
#4 | |
Hi bernard
About your suggestion Quote:
'(u*nabla)u0' ,and these terms cannot be treated as source terms, because they are depended on 'u'. Thus they have to be treated as implicit terms like (u*nabla)u. So, how do we implement these modifications? Should we modify the matrix only or also the PISO loop? Thanks |
May 16, 2012, 09:27 |
look
Lev
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 12:44 |
Using a user-defined solver in OF | ozzythewise | OpenFOAM Running, Solving & CFD | 3 | February 8, 2011 15:28 |
Getting too many iterations by velocity solving (aborting). Changing U - Solver? | suitup | OpenFOAM Running, Solving & CFD | 0 | January 20, 2010 07:45 |
free " ordinary differential equations solver" | ztdep | Main CFD Forum | 2 | March 21, 2006 01:58 |
