find the adjacent face on the boundary
Hello everyone:
I want to find the cells surround one cell "on the boundary", (the cell is face). If I know one face ID, how can I find the faces ID around this face? For example, if the face is quadrangle, I want to find the other 8 faces around it. Could someone know how to deal with it? Thank you! bojiezhang |
- from boundary face, get the owner cell - for this owner cell, get all the associated faces - get the neighbouring cells from the faces - loop through to find the which of the neighbour cell faces to find a boundary face. If you need the "corner" faces, my first approach would be brute force. - from the boundary face you know the vertices, place them in a labelHashSet. - loop through the boundary faces and tag each face that shares a vertex with the original face. A labelHashSet of the face Ids might be useful here. This should work. Instead of looping across all boundary faces, you may want to restrict your search to a particular patch though - for efficency and to avoid finding a neighbour with a different BC treatment. |
use of GroovyBC to acess the data
Dear olesen,
How to get all the associated faces for the owner cell? I wish to use groovyBC for the same. |
Hello
The function name is bit confusing, but to get the faces of a cell called FaceIOwner: Code:
const cell& facesOfOwner = mesh.cells()[FaceIOwner]; |
Thank you for the info.
- Best Regards! |
