Compile error kEpsilonViollet for OF 2.1.1
Old   July 1, 2012, 18:21
Default Compile error kEpsilonViollet for OF 2.1.1
Andreas Herwig
Andreas.Herwig is on a distinguished road
while compiling the kEpsilonViollet model (it is written for OF 1.7 and works fine with OF 1.7)
http://openfoamwiki.net/index.php/Co...EpsilonViollet
under OF 2.1.1 a strange (at least to me) error occurs:
kEpsilonViollet/kEpsilonViollet.C: In member function ‘virtual void Foam::incompressible::RASModels::kEpsilonViollet:: correct()’:
kEpsilonViollet/kEpsilonViollet.C:254:9: error: reference to ‘db’ is ambiguous
/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/IOobject.H:246:35: error: candidates are: const Foam:bjectRegistry& Foam::IOobject::db() const
/opt/OpenFOAM-2.1.1/src/OpenFOAM/lnInclude/IOobject.H:246:35: error: const Foam:bjectRegistry& Foam::IOobject::db() const
I am using the latest gcc (version 4.6.2) compiler. By searching the problem in the web i found something which might be related (but I am not sure):
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=27775
From the original source code of kEpsilonViollet.C it is the part:
    const uniformDimensionedVectorField& g_ =
        db().lookupObject<uniformDimensionedVectorField>("g");
    const volScalarField& T_ = db().lookupObject<volScalarField>(TName_);
which causes the problem. By the way: you can find the similar code snippet
for example in
alphaFixedPressureFvPatchScalarField.C (from /src/transportModels/...)
which compiles without any problems.
If there is somebody knowing what to do to fix this problem: Thank you very much!
Greetings
Andreas
Andreas.Herwig is offline   Reply With Quote
Old   July 2, 2012, 06:25
Default maybe fixed ?
Andreas Herwig
Dear all,
while trying to solve the problem described above i found this thread
http://www.cfd-online.com/Forums/ope...-buoyancy.html
There something similar is discribed and it is said that there is something before the db(). is needed, like ???.db(). So i tried U_.db()
        U_.db().lookupObject<uniformDimensionedVectorField>("g");
    const volScalarField& T_ = U_.db().lookupObject<volScalarField>(TName_);
and it seems to solve the problem. The objectRegistry seems to be attached to a field and does not exist (anymore?) "stand alone", but maybe someone who knows the openfoam source code better then me should answer on this question.
There are some more parts of the kEpsilonViollet code to modify for to transfer it from OF 1.7 to OF 2.1.1. I will publish the fully transferd version later in this thread after i did some tests e.g. comparing the results of a test case calculated with the original code under OF 1.7 to the results with my transfered code under OF 2.1.1
Best regards
andreas
compile error, kepsilonviollet
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
OpenFOAM Foundation Releases OpenFOAM® Version 2.1.1 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 May 31, 2012 09:07
PV3FoamReader compile error.... PEM_GUY OpenFOAM Installation 6 April 5, 2010 17:22
Error compile file udf czfluent Fluent UDF and Scheme Programming 24 September 26, 2009 13:24
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 21:51
