Compiling Error - Need help with C++
Old   July 8, 2012, 06:38
Default Compiling Error - Need help with C++
SiCaRiUs is on a distinguished road
i just need your help in putting an Equation to C++.
The following Code works fine:
    kappat = turbulence->nut()/Prt;
    kappat.correctBoundaryConditions();
    volScalarField kappaEff("kappaEff", turbulence->nu()/Pr + kappat);
    fvScalarMatrix TEqn
        fvm::div(phi, T)
      - fvm::Sp(fvc::div(phi), T)
      - fvm::laplacian(kappaEff, T)
      - ((U & fvc::grad(p)) / Cp)
      - (((turbulence->nuEff() / Cp) * (fvc::grad(U) + fvc::grad(U)().T())) && fvc::grad(U))
    TEqn.relax();
    TEqn.solve();
    rhok = 1.0 - beta*(T - TRef);
But when i want to enhance the equation with one more term, it doesn't work anymore.
Here is the part of the equation i want to put into c++:
This is my try in the code:
    fvScalarMatrix TEqn
        fvm::div(phi, T)
      - (((turbulence->nuEff() / Cp) * (fvc::grad(U) + fvc::grad(U)().T() - (2.0/3.0 * fvm::div(U)))) && fvc::grad(U))
    TEqn.relax();
    TEqn.solve();
But i got the following compiling error:
Making dependency list for source file buoyantBoussinesqSimpleFoamVH211_erw.C
SOURCE=buoyantBoussinesqSimpleFoamVH211_erw.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/turbulenceModels -I/opt/openfoam211/src/turbulenceModels/incompressible/RAS/lnInclude -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/transportModels/incompressible/singlePhaseTransportModel -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/buoyantBoussinesqSimpleFoamVH211_erw.o
In file included from buoyantBoussinesqSimpleFoamVH211_erw.C:77:0:
TEqn.H: In Funktion »int main(int, char**)«:
TEqn.H:13:98: Fehler: keine passende Funktion für Aufruf von »div(Foam::volVectorField&)«
TEqn.H:13:98: Anmerkung: Kandidaten sind:
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:45:1: Anmerkung: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:62:1: Anmerkung: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&, const Foam::word&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:77:1: Anmerkung: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const surfaceScalarField&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
/opt/openfoam211/src/finiteVolume/lnInclude/fvmDiv.C:88:1: Anmerkung: template<class Type> Foam::tmp<Foam::fvMatrix<Type> > Foam::fvm::div(const Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> >&, const Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>&)
make: *** [Make/linux64GccDPOpt/buoyantBoussinesqSimpleFoamVH211_erw.o] Fehler 1
I hope you can help me!
Thanks a lot!
Greetings
Sebastian
SiCaRiUs is offline   Reply With Quote
Old   July 8, 2012, 10:22
Ok. I think i've got it. Just multiplicated the red term with the identity tensor. Now it works.
Problem with Compiling UDFs in Ansys Fluent 13 (lnx64) Ali.beh Fluent UDF and Scheme Programming 3 August 27, 2018 04:22
paraview 3.10.1 compiling error (1.6-ext) vkrastev OpenFOAM Installation 7 October 28, 2011 03:17
Help with KIVA4 source code compiling geothokar Main CFD Forum 0 September 3, 2010 05:40
error msg when compiling user fortran Ollimarc CFX 0 March 13, 2008 18:16
Discussing UDF and C++ Compiling Big Stone FLUENT 9 April 12, 2004 15:07
