August 22, 2012, 06:31 |
Library Linking Problems
Rep Power: 13 |
I created some libraries to calculate the reaction rate in OpenFOAM-2.1.x. Everything worked fine. Now I have to use OpenFOAM-2.0.x. I copied the files with my created libraries in my $WM_PROJECT_USER_DIR an compiled with - wclean - wmake libso No error messages occur. I added the library in my controlDict file and ran the case with rhoReactingFoam. I get the following output: Create time --> FOAM Warning : From function dlOpen(const fileName&, const bool) in file POSIX.C at line 1142 dlopen error : /home/fluent/OpenFOAM/fluent-2.0.x/platforms/linux64Gcc45DPOpt/lib/libPropaneMainReactionRate.so: undefined symbol: _ZN4Foam6specie5debugE --> FOAM Warning : From function dlLibraryTable:pen(const fileName&, const bool) in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 96 could not load "libPropaneMainReactionRate.so" Create mesh for time = 0 Reading chemistry properties Reading g Reading thermophysicalProperties Selecting rhoChemistryModel ODEChemistryModel<gasThermoPhysics> Selecting thermodynamics package hsRhoMixtureThermo<reactingMixture<gasThermoPhysic s>> Selecting chemistryReader foamChemistryReader --> FOAM FATAL ERROR: Unknown reaction type irreversiblePropaneMainReaction Valid reaction types are : 30 ( irreversibleArrheniusLindemannChemicallyActivatedR eaction irreversibleArrheniusLindemannFallOffReaction irreversibleArrheniusReaction irreversibleArrheniusSRIChemicallyActivatedReactio n irreversibleArrheniusSRIFallOffReaction irreversibleArrheniusTroeChemicallyActivatedReacti on irreversibleArrheniusTroeFallOffReaction irreversibleJanevReaction irreversibleLandauTellerReaction irreversibleLangmuirHinshelwoodReaction irreversibleinfiniteReaction irreversiblepowerSeriesReaction irreversiblethirdBodyArrheniusReaction nonEquilibriumReversibleArrheniusReaction nonEquilibriumReversibleLandauTellerReaction nonEquilibriumReversibleinfiniteReaction nonEquilibriumReversiblethirdBodyArrheniusReaction reversibleArrheniusLindemannChemicallyActivatedRea ction reversibleArrheniusLindemannFallOffReaction reversibleArrheniusReaction reversibleArrheniusSRIChemicallyActivatedReaction reversibleArrheniusSRIFallOffReaction reversibleArrheniusTroeChemicallyActivatedReaction reversibleArrheniusTroeFallOffReaction reversibleJanevReaction reversibleLandauTellerReaction reversibleLangmuirHinshelwoodReaction reversibleinfiniteReaction reversiblepowerSeriesReaction reversiblethirdBodyArrheniusReaction ) From function Reaction<ReactionThermo>::New(const speciesTable&, const HashPtrTable<ReactionThermo>&, const dictionary&) in file /home/fluent/OpenFOAM/OpenFOAM-2.0.x/src/thermophysicalModels/specie/lnInclude/Reaction.C at line 353. FOAM exiting In my Make directory I have: - files: makeReactionThermoReactions.C LIB = $(FOAM_USER_LIBBIN)/libPropaneMainReactionRate - options: EXE_INC = \ -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude EXE_LIBS = \ -1thermophysicalModels/specie In my controlDict file I added: libs ("libPropaneMainReactionRate.so") Thanks in advance for any hint, Matari |
August 26, 2012, 07:45 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Matari,
Try this: Code:
wclean libso wmake libso Best regards, Bruno
[Other] Multi species mass transport library [update] | novyno | OpenFOAM Community Contributions | 111 | November 9, 2021 23:37 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Problems in personal library compilation | shrina | OpenFOAM | 3 | February 23, 2009 11:12 |
Problems linking my libraries with libfoamUser | jblucca | OpenFOAM Running, Solving & CFD | 5 | October 22, 2008 16:53 |
Personal library compilation | mss | OpenFOAM Running, Solving & CFD | 1 | September 13, 2007 06:10 |
