Loop over cells slowing down the code
Like Tree2Likes
  • 2 Post By ngj
Old   February 6, 2013, 02:57
Default Loop over cells slowing down the code
Guillaume
Gloq is on a distinguished road
Hi everybody,
I try to create a field for my variable alphath. The value I want to set for this variable depends on space.
Finally, the algorithm should look like :
For all cells
If ( x < xmax and x > xmin) alphath = f(x)
In order to go step by step in the coding process (I'm not really a senior coder in openFoam ...), for the moment, I just try to impose, for all cells,
alphath(x,y,z) = x
I coded this stuff like that :
forAll (mesh.cells(),celli)
alphath[celli] = mesh.C().component(vector::X)()[celli];
Adding these lines in the code REALLY slows it down ...
As a simple test, I replaced "mesh.C().component(vector::X)()[celli]" by "1.0" and the code is quick again.
Do you know why the added lines slow the code down ?
Would you have an alternative coding ?
Thanks in advance for your help.
Guillaume
Gloq is offline   Reply With Quote
Old   February 6, 2013, 03:13
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Guillaume,
I have a small guess, since you are first extracting the x-coordinate from the cell centres and then you get the i'th index (checked the code and a new volScalarField is constructed). This actually means that you make a copy of all of the x-values every time you only need one; so in the end of the day you have a process, which scales with N^2 rather than N.
This should be faster:
forAll( alphath, celli )
     alphath[celli] = mesh.C()[celli].x();
or in this particular case, you could merely have written:
alphath.internalField() = mesh.C().component(vector::X);
Kind regards,
Niels
mm.abdollahzadeh and mrishi like this.
ngj is offline   Reply With Quote
Old   February 6, 2013, 04:15
Guillaume
Hey Niels,
thanks a lot for having taken some of your time for my problem !
Your answer was quick, detailed and (after a test just performed) very efficient !
Thanks again.
Kind regards,
Guillaume
Old   February 6, 2013, 04:25
ngj
Good!
/ Niels
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 19:18
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
for loop inside a cell_loop? MHDWill FLUENT 0 September 26, 2007 21:24
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
