September 17, 2012, 08:22 |
What does this Error mean?
I programmed a Solver, witch works on one PC, now I want to compile the code on an other one and got this error:
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/StaubThermoDust_2D_Mix> wmake Making dependency list for source file StaubEx.C SOURCE=StaubEx.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/cfdTools -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/StaubEx.o /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H: In Funktion »int main(int, char**)«: /opt/openfoam171/src/finiteVolume/lnInclude/readPIMPLEControls.H:12:10: Warnung: Variable »transonic« wird nicht verwendet g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam171/src/finiteVolume/cfdTools -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/StaubEx.o -L/opt/openfoam171/lib/linux64GccDPOpt \ -lbasicThermophysicalModels -lspecie -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix Make/linux64GccDPOpt/StaubEx.o: In function `main': StaubEx.C:(.text+0x3bf8): undefined reference to `Foam::hCombustionThermo::New(Foam::fvMesh const&)' collect2: ld gab 1 als Ende-Status zurück make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/StaubEx2DMix] Fehler 1 nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/StaubThermoDust_2D_Mix> Code:
nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/rhoReactingFoam_test> wmake g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam171/src/turbulenceModels/compressible/turbulenceModel -I/opt/openfoam171/src/thermophysicalModels/specie/lnInclude -I/opt/openfoam171/src/thermophysicalModels/reactionThermo/lnInclude -I/opt/openfoam171/src/thermophysicalModels/basic/lnInclude -I/opt/openfoam171/src/thermophysicalModels/chemistryModel/lnInclude -I/opt/openfoam171/src/ODE/lnInclude -I/opt/openfoam171/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam171/src/OpenFOAM/lnInclude -I/opt/openfoam171/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed Make/linux64GccDPOpt/rhoReactingFoam.o -L/opt/openfoam171/lib/linux64GccDPOpt \ -lbasicThermophysicalModels -lspecie -lcompressibleTurbulenceModel -lcompressibleRASModels -lcompressibleLESModels -lfiniteVolume -lmeshTools -lOpenFOAM -liberty -ldl -lm -o /home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test Make/linux64GccDPOpt/rhoReactingFoam.o: In function `main': rhoReactingFoam.C:(.text+0x23a8): undefined reference to `Foam::rhoChemistryModel::New(Foam::fvMesh const&)' collect2: ld gab 1 als Ende-Status zurück make: *** [/home/nem/OpenFOAM/nem-1.7.1/applications/bin/linux64GccDPOpt/rhoReactingFoam_test] Fehler 1 nem@linux-81gf:~/OpenFOAM/nem-1.7.1/Solvers/rhoReactingFoam_test> Christoph |
September 17, 2012, 09:17 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Christoph,
Are both machines using the same version of OpenFOAM? Best regards, Bruno
September 17, 2012, 09:55 |
Yes, both 1.7.1, I have now solved the problem by recompiling OpenFoam. It seams that the computer wasn’t set up properly.
Christoph |
