FvPatchFields - read and write values in a patch |
December 11, 2012, 13:47 |
Vitor Vasconcelos
Rep Power: 14 |
Hello fellows,
I'll start replying myself. Sorry for that. I've been doing research and diving into openfoam C++ documentation. I got some interesting results, but I am kind of stucked again. I am implementing a BC based of fixedValueFvPatchField. Althought I want to change values in the future, I'm using this as base class as a training to understand openFoam BC's rationale. Right now I'm able to read faces from my patch and, for example, get the normals of these faces. Quite promising, but I have two big doubts about how things work. First one: I created a mesh (following a former post of this forum) and based on it I got my patch (it is a wall which is a heat source) and was able to iterate over it face by face. I could do it using the mesh but I also tried to use a *this of my class. With both I got the same result. However, in my 0/T file I started my variable as nonuniform scalar from 1 to 840, which are the number of faces I have (attached are the my geometry). My point is: how to access the different temperatures of each cell? I was wondering it could be stored as "weights" for faces. But the face.normal() and face.mag() are always the same. My mesh is hexaedrical and, in fact, all faces have the same size. However, the nonuniform values are clearly different from cell to cell. Which data strucutres should I read? The second point is also inside the first? is it ok to use a IOobject mesh to get values or is better to use this->patch().patch()? My code is also attached. Sorry for the mess, but it is full of "Info" and very personal comments. Code: Code:
template<class Type> cosFixedValueFvPatchField<Type>::cosFixedValueFvPatchField ( const fvPatch& p, const DimensionedField<Type, volMesh>& iF, const dictionary& dict ) : fixedValueFvPatchField<Type>(p, iF), refValueLow_("refValueLow", dict, p.size()), refValueHigh_("refValueHigh", dict, p.size()), startRamp_(readScalar(dict.lookup("startRamp"))), endRamp_(readScalar(dict.lookup("endRamp"))), curTimeIndex_(-1) { if (dict.found("value")) { fixedValueFvPatchField<Type>::operator== ( Field<Type>("value", dict, p.size()) ); } else { Info << "|||||||||||| Entered fixedValue operator== |||||||||||\n" << endl; fixedValueFvPatchField<Type>::operator== ( // refValueLow_ + (refValueHigh_ - refValueLow_)*currentScale() refValueLow_ ); } // Tentativa de ler o valor da gravidade uniformDimensionedVectorField gv(IOobject ("g", this->db().time().constant(), this->db(), IOobject::MUST_READ, IOobject::NO_WRITE) ); Info << "---- Saida g: " << gv << endl; //Tentando variar os valores do proprio campo (patchField) // Cria o mesh Foam::fvMesh mesh(Foam::IOobject( Foam::fvMesh::defaultRegion, this->db().time().timeName(), this->db().time(), Foam::IOobject::MUST_READ )); // Trying to understand the mesh and polypatch relation label patchID = mesh.boundaryMesh().findPatchID("combustivel"); Info << "patchID: " << patchID << endl; // const polyPatch& patchFound = mesh.boundaryMesh()[patchID]; const polyPatch& patchFound = this->patch().patch(); Info << "patchFound: \n" << patchFound << endl; labelList labelPatchFound( patchFound.meshPoints() ); Info << "Tamanho da lista de pontos: " << labelPatchFound.size() << endl; vectorList faceNormals(patchFound.size(), vector::zero); scalarList faceMag(patchFound.size()); Info << "Face inicial: " << patchFound.start() << endl; labelList minhasFaces(patchFound.faceCells()); Info << "Tamanho da lista de faces: " << minhasFaces.size() << endl; // Verificando as direcoes do mesh Info << "geometricD: " << mesh.geometricD() << endl; // Tentar extrair apenas as faces com a normal no x positiva pointField meshPoints(mesh.points()); unsigned int pr = 0; forAll(patchFound, faceI) { // const face& myFace = mesh.boundaryMesh()[patchID][faceI]; const face& myFace = this->patch().patch()[faceI]; faceNormals[faceI] = myFace.normal(mesh.points()); // faceMag[faceI] = myFace.mag(mesh.points()); if(faceNormals[faceI].x() > 0) { //Info << faceNormals[faceI] << " "; Info << faceI << " "; pr++; } } Info << "\n\n--- Numero de faces com normal x positiva: " << pr << endl; const scalarField& pesos = this->patch().weights(); Info << "size of scalarField: " << pesos.size() << "scalarField: \n" << pesos << endl; } Thanks for your time, Vitor Last edited by vitors; December 11, 2012 at 13:52. Reason: Improve code visualization |
mesh file for flow over a circular cylinder | Ardalan | Main CFD Forum | 7 | December 15, 2020 13:06 |
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh | elvis | OpenFOAM Community Contributions | 210 | January 30, 2017 18:57 |
Journal file clicks buttons but doesn't write values, why? | kingjewel1 | FLUENT | 2 | April 3, 2012 04:30 |
How to read or write case by commands during simulation with Fluent | lzgwhy | FLUENT | 4 | April 20, 2011 22:02 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 14:37 |
