dimensioned problem in potentialFoam
Old   December 20, 2012, 09:31
Default dimensioned problem in potentialFoam
T.Matrix is on a distinguished road
there is a define of pressure p as follow in the createFields.H in the potentialFoam:
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::NO_WRITE
mesh
p = dimensionedScalar("zero", p.dimensions(), 0.0);
In my opinion, the pressure p is created with dimensionedless at first, and then assign its dimension according to dimensionedScalar("zero", p.dimensions(), 0.0). However, when p.dimensions() is called, the dimension of p in left is still dimensionless. Therefore, the dimension of p is not given.
At the same time, the same problem is also exist in the velocity U.
T.Matrix is offline   Reply With Quote
Old   December 20, 2012, 14:36
Lieven
Lieven will become famous soon enough
Hey T.Matrix,
The dimensions of p and U should be read from the input files. So if p.dimensions() is dimensionless, you should check the dimension set specified in 0/p and 0/U of the case.
Kind regards,
L
Lieven is offline   Reply With Quote
Old   December 21, 2012, 20:23
Hi Lieven,
the dimensions of p and U is given in the input files as normal, and potentialFoam can run correctly. However, the problem is how the dimensions is assigned in the source code. As far as I am concerned, volscalarField p is created by calling construction function GeometricField(*,*,*). In the following code, dimensions is not given to the construction GeometricField. Therefore, pressure p is created using the default dimension which is set dimensionless in the construction. So, in my opinion, p is created with no dimension. In fact, when source code is executed, p has its own dimension. I can't understand it.
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::NO_WRITE
mesh
Old   December 22, 2012, 04:16
Lieven
Dear T.Matrix,
So, in my opinion, p is created with no dimension..
The dimensions are not given explicitly in the source code but they are effectively read from the input file because IOobject::MUST_READ is set. This give the user the flexibility to chose them himself. Only when IOobject::MUST_READ would be IOobject::NO_READ or IOobject::READ_IF_PRESENT on the other hand, they would need to be provided in the source code.
If you add
Info << p.dimensions() << endl;
just before
you can verify yourself that the dimensions are taken from the input file (simply change them a few times)
The only reason
is added to the createFields.H is to reset the pressure field to 0.
Kind regards,
L
Old   December 22, 2012, 05:48
Hello L,
If Oobject::MUST_READ is set, the dimension is read from input file. However, the dimension is saved in a temporary IOobject. I just do not know how this temporary IOobject transport its dimension to dimension in volScalarField. I read relative codes several days but have no idea.
Matrix.T
dimensioned
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Problem in implementing cht tilek CFX 3 May 8, 2011 08:39
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
