July 15, 2010, 16:59 |
nonNewtonian viscosity model
Muhammad reza hassani
Rep Power: 16 |
Hi, I want to use a non-Newtonian viscosity model other than those predefined in the source directory; the modification can be done by changing the formulation in CrossPowerLaw.C.
The question here is: Do I need to compile the file after modification? Do I have to copy it somewhere else (e.g. user directory) make the changes, create a "Make" folder compile it using wmake or something else can be done more straight forward? |
July 15, 2010, 17:23 |
Rep Power: 16 |
after making the changes, I create a make file in user directory trying to compile it several errors occurred; any idea what the problem can be? the error is:
Making dependency list for source file GenPowerLaw.C could not open file volFieldsFwd.H for source file GenPowerLaw.C could not open file surfaceFieldsFwd.H for source file GenPowerLaw.C could not open file volFields.H for source file GenPowerLaw.C could not open file surfaceFields.H for source file GenPowerLaw.C SOURCE=GenPowerLaw.C ; g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/openfoam170/src/transportModels/incompressible/lnInclude -IlnInclude -I. -I/opt/openfoam170/src/OpenFOAM/lnInclude -I/opt/openfoam170/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linuxGccDPOpt/GenPowerLaw.o In file included from GenPowerLaw.H:38, from GenPowerLaw.C:26: /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:48:26: error: volFieldsFwd.H: No such file or directory /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:49:30: error: surfaceFieldsFwd.H: No such file or directory In file included from GenPowerLaw.C:26: GenPowerLaw.H:40:23: error: volFields.H: No such file or directory GenPowerLaw.C:28:27: error: surfaceFields.H: No such file or directory In file included from GenPowerLaw.H:38, from GenPowerLaw.C:26: /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:73: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:73: error: expected ‘;’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:74: error: ISO C++ forbids declaration of ‘surfaceScalarField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:74: error: expected ‘;’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: expected ‘,’ or ‘...’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: expected ‘,’ or ‘...’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:116: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:116: error: expected ‘,’ or ‘...’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:128: error: ISO C++ forbids declaration of ‘volVectorField’ with no type /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:128: error: expected ‘,’ or ‘...’ before ‘&’ token /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:148: error: ‘volScalarField’ was not declared in this scope /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:148: error: template argument 1 is invalid /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:151: error: ‘volScalarField’ was not declared in this scope /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:151: error: template argument 1 is invalid /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H: In static member function ‘static Foam::autoPtr<Foam::viscosityModel> Foam::viscosityModel::adddictionaryConstructorToTa ble<viscosityModelType>::New(const Foam::word&, const Foam::dictionary&, int)’: /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: ‘U’ was not declared in this scope /opt/openfoam170/src/transportModels/incompressible/lnInclude/viscosityModel.H:94: error: ‘phi’ was not declared in this scope In file included from GenPowerLaw.C:26: GenPowerLaw.H: At global scope: GenPowerLaw.H:70: error: ‘volScalarField’ does not name a type GenPowerLaw.H:75: error: ‘volScalarField’ was not declared in this scope GenPowerLaw.H:75: error: template argument 1 is invalid GenPowerLaw.H:91: error: ISO C++ forbids declaration of ‘volVectorField’ with no type GenPowerLaw.H:91: error: expected ‘,’ or ‘...’ before ‘&’ token GenPowerLaw.H:105: error: ‘volScalarField’ was not declared in this scope GenPowerLaw.H:105: error: template argument 1 is invalid GenPowerLaw.H: In member function ‘virtual int Foam::viscosityModels::GenPowerLaw::nu() const’: GenPowerLaw.H:107: error: ‘nu_’ was not declared in this scope GenPowerLaw.H: In member function ‘virtual void Foam::viscosityModels::GenPowerLaw::correct()’: GenPowerLaw.H:113: error: ‘nu_’ was not declared in this scope GenPowerLaw.C: At global scope: GenPowerLaw.C:50: error: ‘volScalarField’ is not a member of ‘Foam’ GenPowerLaw.C:50: error: ‘volScalarField’ is not a member of ‘Foam’ GenPowerLaw.C:50: error: template argument 1 is invalid GenPowerLaw.C: In member function ‘int Foam::viscosityModels::GenPowerLaw::calcNu() const’: GenPowerLaw.C:53: error: argument of type ‘int (Foam::viscosityModel:()const’ does not match ‘int’ GenPowerLaw.C:53: error: ‘nuInf’ was not declared in this scope GenPowerLaw.C:53: error: ‘deltaNu’ was not declared in this scope GenPowerLaw.C: At global scope: GenPowerLaw.C:63: error: ISO C++ forbids declaration of ‘volVectorField’ with no type GenPowerLaw.C:63: error: expected ‘,’ or ‘...’ before ‘&’ token GenPowerLaw.C: In constructor ‘Foam::viscosityModels::GenPowerLaw::GenPowerLaw(c onst Foam::word&, const Foam::dictionary&, int)’: GenPowerLaw.C:67: error: ‘U’ was not declared in this scope GenPowerLaw.C:67: error: ‘phi’ was not declared in this scope GenPowerLaw.C:77: error: class ‘Foam::viscosityModels::GenPowerLaw’ does not have any field named ‘nu_’ GenPowerLaw.C:82: error: ‘U_’ was not declared in this scope make: *** [Make/linuxGccDPOpt/GenPowerLaw.o] Error 1 |
July 15, 2010, 17:27 |
Rep Power: 16 |
the files in Make directory contains:
GenPowerLaw.C EXE = $(FOAM_LIBBIN)/libViscosityMod and in options: EXE_INC = \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude EXE_LIBS = \ -ltransportModel the problems are still unsolved! |
July 16, 2010, 07:25 |
Martin
Rep Power: 21 |
Hi Muhammad,
the "options" file must have the line -I$(LIB_SRC)/finiteVolume/lnInclude \ as well. My recommendation is: create your own viscosity model in the OpenFOAM's source directory... just make your new "GenPowerLaw" folder next to OpenFOAM's "powerLaw" folder. Edit "/opt/openfoam170/src/transportModels/incompressible/Make/files" by adding the line: "viscosityModels/GenPowerLaw/GenPowerLaw.C" Navigate in your shell to "/opt/openfoam170/src/transportModels/incompressible/" and call "wclean" Then navigate to "/opt/openfoam170/src/transportModels/" and call "./Allwmake" Hope it helps Martin |
January 7, 2013, 09:10 |
Ehsan
Rep Power: 15 |
Dear Martin, I want to create a folder in the viscosity model directory but it fails, I cannot create a folder? may you help me?
January 7, 2013, 09:27 |
Martin
Rep Power: 21 |
Hi Ehsan,
you need write access to the directory where you want to create the new viscosity model. It is better to use your user directory instead of the OpenFOAM's source directory. In this post you can find an example how to do it: http://www.cfd-online.com/Forums/ope...tml#post375899 Martin |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Implementing new viscosity model | prjohnston | OpenFOAM Running, Solving & CFD | 6 | July 3, 2015 04:26 |
Yielding viscosity for Herschel Bulkley model | Godwin | FLUENT | 1 | December 12, 2011 05:42 |
Power Law Viscosity Model | cpplabs | OpenFOAM Running, Solving & CFD | 1 | February 13, 2008 08:09 |
Casson Viscosity model as one user define function | Zahra Rahmdel | FLUENT | 0 | November 6, 2004 05:53 |
