Hi,I have a question about momentum equation in interFoam |
January 11, 2013, 09:19 |
anonymous
Dear Foamers:
I have read Henrik Rusche's phd thesis.Now i meet a question in the momentum equation of interFoam. Mr. Rusche defined an 'H' operator AH=As-An*phi where 'As' means source vector.Does As include the item like -grad(p)-g*x*grad(rho)...?Or What included in As?Thank you very much! |
January 13, 2013, 05:59 |
Fumiya Nozaki
Rep Power: 18 |
Take a look at the interFoam/UEqn.H:
fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) + turbulence->divDevRhoReff(rho, U) == sources(rho, U) ); fvVectorMatrix UEqn. In the above definition of UEqn, there is no terms corresponding to grad(p) and g*x*grad(rho), so these terms are not included in the H operator in the interFoam solver. Fumiya |
January 14, 2013, 07:47 |
anonymous
Here's the UEqn.H in of 2.1.1
surfaceScalarField muEff ( "muEff", twoPhaseProperties.muf() + fvc::interpolate(rho*turbulence->nut()) ); fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) - fvm::laplacian(muEff, U) - (fvc::grad(U) & fvc::grad(muEff)) //- fvc::div(muEff*(fvc::interpolate(dev(fvc::grad(U)) ) & mesh.Sf())) ); UEqn.relax(); if (pimple.momentumPredictor()) { solve ( UEqn == fvc::reconstruct ( ( fvc::interpolate(interface.sigmaK())*fvc::snGrad(a lpha1) - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) ) * mesh.magSf() ) ); } The H operator is constructed by : fvVectorMatrix UEqn ( fvm::ddt(rho, U) + fvm::div(rhoPhi, U) - fvm::laplacian(muEff, U) - (fvc::grad(U) & fvc::grad(muEff)) //- fvc::div(muEff*(fvc::interpolate(dev(fvc::grad(U)) ) & mesh.Sf())) ); Right? |
January 28, 2013, 21:27 |
Santiago Marquez Damian
Rep Power: 23 |
Hi, the H operator gives which is defined in Hrv thesis for the implicit terms used in the fvVectorMatrix declaration.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D. Research Scientist Research Center for Computational Methods (CIMEC) - CONICET/UNL Tel: 54-342-4511594 Int. 7032 Colectora Ruta Nac. 168 / Paraje El Pozo (3000) Santa Fe - Argentina. http://www.cimec.org.ar |
November 13, 2017, 11:05 |
#6 | |
behzad Ghasemi
Rep Power: 12 |
I've a question about momentum equation of interFoam. why Area (mesh.magSf()) is multiplied to RHS of equation? |
December 18, 2017, 17:34 |
Tobias Holzmann
Rep Power: 51 |
This is based on the divergence operator. We interpolate the deviatoric part of grad(U) to the face and have to multiply it with the surface normal vector (area of the face). As it is given in Hrv thesis, the divergence is approximately the sum of fluxes through the faces.
Keep foaming, Tobias Holzmann |
December 18, 2017, 17:40 |
#8 | |
behzad Ghasemi
Rep Power: 12 |
Regards, |
solving the momentum equation in UEqn. | callahance | OpenFOAM | 2 | October 18, 2012 09:38 |
momentum equation question | mauz | Main CFD Forum | 0 | March 26, 2010 11:34 |
Momentum equation used by mixture model | George | FLUENT | 0 | May 19, 2005 13:07 |
Problem with momentum equation | Francisco | Main CFD Forum | 4 | August 5, 2004 20:04 |
Nonstaggered Grids and Momentum Interpolations | S. Wang | Main CFD Forum | 3 | March 2, 2001 13:44 |
