March 5, 2013, 05:47 |
Loop over Points of a boundary / patch
HECKMANN Frédéric
Dear all,
I am looking for a code able to loop over the points of a patch. From my research it seems that there is no member to find the points of a face. How can we get from a known face the corresponding nodes ? My idea is to get an algorithm like this - get patch id - loop over face of the patch - loop over the points of the faces -> do a point treatment (an arbitraty movement in my case) Thx in advance |
March 5, 2013, 07:49 |
meshPoints() function
Fumiya Nozaki
Rep Power: 18 |
You can use the meshPoints() function.
The following thread will be of help: http://www.cfd-online.com/Forums/ope...ary-patch.html Fumiya |
March 7, 2013, 03:19 |
HECKMANN Frédéric
Your link is quite useful ! It's not perfect but still really good. I guess there is no elegant way to do what I want.
Thx. |
May 25, 2015, 04:34 |
#4 | |
Fei Fan
Rep Power: 12 |
Have you solve this question now. I have the same problem to access the nodes of face. could you give me a hints. Thanks. Best regards Fan Fei |
July 8, 2015, 10:52 |
#5 | |
Bruno Blais
Rep Power: 12 |
Here is an example (somebody might correct me, this is not perfect) on how to loop over a boundary patch of which the name is "left". Then you get the position at the center of the face and you apply a function, let's say a cosine in this case. Code:
label inletPatchID = mesh.boundaryMesh().findPatchID("left"); //Patch identifier of the boundary condition fvPatchScalarField& wallP = p.boundaryField()[inletPatchID]; // Obtain a patchScalar field on the BC forAll(wallP, faceI) // Loop over each face of the patch { vector pos(mesh.Cf().boundaryField()[inletPatchID][faceI]); x = pos[0]; y = pos[1]; wallP[faceI]=Foam::cos(PI*x)*Foam::cos(PI*y);; } |
July 8, 2015, 10:57 |
#6 | |
Fei Fan
Rep Power: 12 |
Thanks for you reply me. this problem i have solved. I use lablist to access to the face vertices series number and use mesh.points() to get the coordinate of points. Best regards Fan Fei |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 12:46 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 02:34 |
