adiabaticPerfectFluid in compressibleInterFoam not valid?
Old   September 13, 2013, 14:18
Default adiabaticPerfectFluid in compressibleInterFoam not valid?
ma-tri-x is on a distinguished road
Hi everyone!
I want to calculate a bubble with compressibleInterFoam with version 2.2.1.
In the TermoPhysicalPropertiesair or ""water you can specify the equationOfState that is used. However it seems that adiabaticPerfectFluid (provided with the source code) is not a valid option. If I type "bla" into the entry and look at the list in the error message, only incompressiblePerfectFluid, PerfectGas, PerfectFluid, icoPolynomial are shown as valid. Is this an error in the code or am I wrong? I would like to use the equation from adiabaticPerfectFluid.
Thanks!
ma-tri-x is offline   Reply With Quote
adiabaticperfectfluid, compressibleinterfoam, termophysicalproperties, version 2.2.1
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 14:07
Errors during exporting from Gambit to Fluent redrum FLUENT 3 August 6, 2014 22:40
OpenFoam Doesn't recognize LESModel as a valid selection thomas99 OpenFOAM Programming & Development 4 September 14, 2013 09:24
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
help: Is "no-slip" valid all the time? Pei-Ying Hsieh Main CFD Forum 7 June 26, 2000 10:51
