writing out a volScalarField
Hi!
I would like another variable to be written to the output, namely, I'm using the porousInterFoam solver and I would like to write mu every writeInterval. I tried it with Code:
mu.write() Code:
mu = twoPhaseProperties.mu() Quote:
Thank you, Natalie |
Why don't you write out nu?, if you look at the error then nu (volScalarField) seems to be available with respect to your code. |
Hi!
I want to write mu since mu is somehow interpolated due to the twoPhases and I want to have a look at that.. nu is an input parameter and should be constant over the entire domain. greetings, Natalie |
create a file named "mu" in your case folder inside a 0 folder & set all BC as 0 value. |
if yes, could you please let me know how? |
