Adding linear generation in InterFOAM
Old   June 10, 2013, 22:51
Default Adding linear generation in InterFOAM
Luca Giannelli
voingiappone is on a distinguished road
Hello everybody,
I am trying to do something which is probably trivial but I don't find the proper formulation.
I have managed to add a tracer in my InterFOAM simulation by adding a jump condition as per this thread. Now I just want to overcome the lack of chemical reactions in the modified solver by adding a simple parameter. I can calculate an approximate generation term knowing the daily performance of my reactor (it is a bioreactor so it is really slow) and I can add it as follow (the K parameter):
\frac{\partial C}{\partial t}+\nabla \cdot \phi C + \nabla\cdot D \nabla C -\nabla K_{gen} = \nabla \cdot D C_{eq}\nabla \alpha
Let's say I have algae growing on CO2 and I want to see how its concentration decreases along the X axis only (linear reactor with negligible culture depth solved in 2D neglecting the y direction). How do I specify not to solve the \nabla K_{gen} along the z axis???
I am quite sure it's a really easy task but I don't know even what to look for.
Thank you everybody for your help
Luca
voingiappone is offline   Reply With Quote
Old   June 11, 2013, 04:05
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Originally Posted by voingiappone View Post
Hello everybody,
Luca
Would this be feasable:
\frac{\partial C}{\partial t}+\nabla \cdot \phi C + \nabla\cdot D \nabla C -\nabla K_{gen}\cdot \left(\begin{array}{c}1\\1\\0\\\end{array}
\right) = \nabla \cdot D C_{eq}\nabla \alpha
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   June 12, 2013, 21:30
Luca Giannelli
Akidess, thanks for the quick reply.
Of course what you wrote is right but I don't know how to translate it in viable code. The equation I wrote in my post above is now (before additions):
fvm::ddt(C)
+ fvm::div(phi, C)
+ fvm::laplacian(DC, C)
- fvc::laplacian(DCeq, alpha1)
I am using this code on a daily base without problems. Now, I don't have any clue on how to implement that vector... So, in coding language, what should I write? Looking through the documentation I found the product between two vectors needs to be represented like [A & B], thus:
fvm::ddt(C)
+ fvm::div(phi, C)
+ fvm::laplacian(DC, C) & (1 1 0)
Would this be correct?
Thank you.
Old   June 13, 2013, 04:14
akidess's Avatar
Anton Kidess
Your code does not match your equation. You completely dropped grad(K)?
fvm::ddt(C)
+ fvm::div(phi, C)
+ fvc::grad(K) & vector(1 1 0)
Old   June 13, 2013, 04:40
Luca Giannelli
fvm::ddt(C)
+ fvm::div(phi, C)
You're right... sorry! I just copy-pasted it from the other file (present formulation) and forgot to add the grad(K) part.
Thank you very much for your help in the proper formulation too! I will add it in the code and post the results even though I suppose it will work right out of the box.
Thank you for your kind help!
Old   June 13, 2013, 04:50
akidess's Avatar
Anton Kidess
Actually, no. I just realized I forgot to add commas between the components of the vector
Old   June 13, 2013, 04:54
Luca Giannelli
Okey dokey!
Actually I thought it was right that way.... why would you use different notations for the same vector in different part of OF (ie the source files and the boundary conditions)? Will place also the commas then!
Old   June 13, 2013, 05:12
akidess's Avatar
Anton Kidess
In C++ you don't really have a choice - the compiler won't treat the whitespace as delimiter for the arguments (as it does with commas). Why the makers of OpenFOAM decided to go with a different syntax in the case files only they know
Old   June 14, 2013, 00:47
Luca Giannelli
It works like a charm!!
Thank you for the hints and help
Luca
A turbulent test case for rhoCentralFoam immortality OpenFOAM Running, Solving & CFD 13 April 20, 2014 06:32
error on turbulence scheme immortality OpenFOAM Pre-Processing 11 August 21, 2013 08:45
suitable boundary condition for scavenging process? immortality OpenFOAM Running, Solving & CFD 3 January 25, 2013 19:10
how to modify fvScheme to converge? immortality OpenFOAM Running, Solving & CFD 15 January 16, 2013 13:06
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
