Making a 1.6.x solver compatible with 2.2.0
Like Tree2Likes
  • 1 Post By kilroy
  • 1 Post By Bernhard
Old   June 28, 2013, 16:25
Default Making a 1.6.x solver compatible with 2.2.0
kilroy's Avatar
kilroy is on a distinguished road
I am trying to modify a custom made solver (shipFoam) which works in v1.6.x. My goal is to make that solver compatible with the v2.2.0. The solver is written by modifying "interDyMFoam". I am not a C++ expert and I don't want to spend too much time on that task.
Does that task require too much effort?
What is the best place to start with?
Thank you for your help in advance,
Best
Kilroy
immortality likes this.
kilroy is offline   Reply With Quote
Old   June 29, 2013, 20:35
immortality's Avatar
Ehsan
immortality is on a distinguished road
what a good idea!
I think must be a general way to do it.
Why didn't name it shipSwapFoam?
Injustice Anywhere is a Threat for Justice Everywhere.Martin Luther King.
To Be or Not To Be,Thats the Question!
The Only Stupid Question Is the One that Goes Unasked.
immortality is offline   Reply With Quote
Old   June 29, 2013, 21:01
kilroy's Avatar
Originally Posted by immortality View Post
what a good idea!
Or swap4Foam
Old   July 8, 2013, 02:29
Bernhard
Bernhard is on a distinguished road
TL;DR: Use Meld ( http://meldmerge.org/ )
I would suggest to use tools like Meld: http://meldmerge.org/
Start by meld-ing the interDymFoam solvers from 1.6 and 2.2, and study the differences. Also, meld the 1.6 original and your version of the solver, to see what exactly you have added.
Then, make a copy of your 1.6 solver to a 2.2 user-folder. Meld the 2.2 original version with your new version. Using the arrows in Meld, you can easily copy code to the 2.2 version of your solver. In case of many difference, just start to compile and find out where the compiler trips, this would be a good starting point.
Finally, don't forget to run a few test cases, to see if your solver still performs as it should.
Bernhard is offline   Reply With Quote
Old   July 8, 2013, 09:11
kilroy's Avatar
Many thanks Bernhard, I will start looking into it.
GPU Linear Solvers for OpenFOAM gocarts OpenFOAM Announcements from Other Sources 37 August 17, 2022 14:22
problem in making a new solver!!! adambarfi OpenFOAM Running, Solving & CFD 18 September 29, 2012 11:56
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
Error during Solver cfd guy CFX 4 May 8, 2001 06:04
