Programming questions
Like Tree52Likes
Old   November 24, 2009, 15:28
Default Programming questions
Sylvain Martel
smart is on a distinguished road
Hi all,
I would like to know what is the meaning of the following terms .A(), .H(), .T():
volScalarField AU = UEqn().A()
U = UEqn().H()/AU
fvc::div(nueff()*dev(fvc::grad(U)().T()))
In addition, could somebody tell me what is the meaning of the "dev" function?
Finally, what is the meaning of "&" in the following line:
phi = fvc::interpolate(rho*U) & mesh.Sf();
Is this "phi" in the UEqn is the same as the one in the pEqn?
Thank you very much to help me understand more about these think.
Sylvain
Zhiheng Wang and alainislas like this.
smart is offline   Reply With Quote
Old   November 24, 2009, 22:25
Eelco van Vliet
eelcovv is on a distinguished road
Hi Sylvain,
I am not an OpenFoam expert, but just started digging into the code and came op with the same questions. For the first question I can refer to
http://physics.ucsd.edu/students/cou.../Tutorial2.pdf
slide 9, where they summarise
- A() returns the central coefficients of an fvVectorMatrix
- H() returns the H operation source of an fvVectorMatrix
- Sf() returns cell face area vector of an fvMesh
- flux() returns the face flux field from an fvScalarMatrix
This terms are related to the PISO solution algorithm, a short explanation is given in
http://www.ifdmavt.ethz.ch/education...ols_slides.pdf
slide 48.
The & is the mathematic cross product vector operator (usually denoted with X). If you want calculate the flux field through a surface (in this case the mass flow), you should multiply the velocity vector with the vector representing the cell face using a cross product, i.e. phi_f = rho u_f X S_f
As far as I understood phi is always the mass flux field through the cell faces. Please, anybody correct me if I am wrong
Hope this helps,
Regards
Eelco
eelcovv is offline   Reply With Quote
Old   November 24, 2009, 22:48
Default correction
Eelco van Vliet
Sorry, the mass flux through a surface is of course given by the inner product between the velocity and the surface face vector, therefore & should represent the inner product vector operator. That by the way leaves me with a question, because with the inner product you get a scalar, not a vector. Is phi a scalar field of a vector field ? Perhaps somebody could explain.
cheers,
Eelco
Zhiheng Wang likes this.
Old   November 24, 2009, 23:19
Mathieu Olivier
mathieu is on a distinguished road
A few fast answers:
1. phi is a surfaceScalarField that represents the mass flux through each faces. It is used in convective terms.
2. The .T() function returns the transpose of a tensor (grad(U) in this case).
3. The dev function returns the deviatoric part of a tensor.
4. Generally, phi is not exactly the same in both equations (momentum and pressure). In the momentum equation, phi is the corrected flux from the previous iteration/timestep. In the pressure equation, phi is the mass flux without the "pressure contribution":
U = rUA*UEqn.H();
phi = fvc::interpolate(U) & mesh.Sf();
Hope this helps,
Mathieu
Bufacchi, Matt_B, Thamali and 1 others like this.
mathieu is offline   Reply With Quote
Old   November 25, 2009, 02:55
Kathrin Kissling
kathrin_kissling is on a distinguished road
Mathieu,
you also wanna try to use the Programmers Guide, which can be found under
http://foam.sourceforge.net/doc/Guid...mmersGuide.pdf
This might help a lot.
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   November 25, 2009, 14:49
Sylvain Martel
Thank you for answers!
What is the meaning of A() and other therms? Now, I know that A() returns the central coefficients of an fvVectorMatrix, but can someone tell me more about each term to have a better understanding of each one?
Thank you all,
Sylvain
Old   November 25, 2009, 14:59
Mathieu Olivier
Hi Sylvain,
You may find answers in many finite volume CFD books. Furthermore, let me suggest you prof Jasak's thesis where the nomenclature is very similar to the one used in OpenFOAM:
http://powerlab.fsb.hr/ped/kturbo/Op...jeJasakPhD.pdf
Regards,
Mathieu
Old   December 3, 2009, 11:28
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
.A() - diagonal elements of matrix
.H() - off-diagonal
ddt(rho U) + div(rho*U*U) - div(nu grad(U)) = - grad(p)
A() U - H() = - grad(p)
.T() - transpose of matrix
& - scalar product
Bufacchi, songwukong, mgg and 5 others like this.
mkraposhin is offline   Reply With Quote
Old   January 6, 2010, 08:45
Dr. Alexander Vakhrushev
makaveli_lcf is on a distinguished road
Send a message via ICQ to makaveli_lcf
Hi all!
Could some one please give more detailed description for flux correction in PISO loop:
phi = (fvc::interpolate(U) & mesh.Sf())
+ fvc::ddtPhiCorr(rUA, U, phi);
How do we get part denoted as "fvc::ddtPhiCorr(rUA, U, phi)"?
My question is regarding implicit pressure resistance for porous media, because there for class porousZone we use tmp<volTensorField> trTU representing rUA in explicit case.
How ddtPhiCorr method should be modified to be able to use volTensorField instead of volScalarField?
Ok, I already have found in http://foam.sourceforge.net/doc/Doxy...8H_source.html
00013 // ddtPhiCorr not well defined for cases with porosity
00014 phi = fvc::interpolate(rho)*(fvc::interpolate(U) & mesh.Sf());
So still waiting for your comments concerning this point.
Best regards,
Dr. Alexander VAKHRUSHEV
Christian Doppler Laboratory for "Metallurgical Applications of Magnetohydrodynamics"
Simulation and Modelling of Metallurgical Processes
Department of Metallurgy
University of Leoben
http://smmp.unileoben.ac.at
makaveli_lcf is offline   Reply With Quote
Old   January 11, 2010, 15:27
mkraposhin's Avatar
Matvey Kraposhin
Originally Posted by makaveli_lcf View Post
Hi all!
Hi, i'm not sure i can help, but i'll try.
Suggest your flow to be incompressible, take look at this files (numbered by order of calling in program):
1) OpenFOAM-1.6/src/finiteVolume/finiteVolume/fvc/fvcDdt.C, function ddtPhiCorr(rA, U, phi), lines 106-125
2) OpenFOAM-1.6/src/finiteVolume/finiteVolume/ddtSchemes/EulerDdtScheme/EulerDdtScheme.C, procedure EulerDdtScheme<Type>::fvcDdtPhiCorr(rA, U, phiAbs). lines 372 - 402
3) OpenFOAM-1.6/src/finiteVolume/finiteVolume/ddtSchemes/ddtScheme/ddtScheme.C, procedure ddtScheme<Type>::fvcDdtPhiCoeff(U, phi), lines 138-233
1) Function #1 calls appropriate type of function #2.
2) Function #2 evaluates difference between old value of flux and flux, calculated with old values of velocity. Then, Function #3 is called to calculate value of Kc (see attached file for more explanation)
3) Function #3 evaluates proportion between flux difference (calculated in #2 and given (current) flux values). Proportion should be between some small epsilon and 1 (unity). Evaluated field returned to #2
4) In Function #2, calculated value phi_d multiplied by 1/A, 1/dt and Kc (previous step) and returned.
For more explanations, see attached file
Old   January 12, 2010, 01:51
Thank you Matvej for such detailed explanations! Now this point is clear for me.
All the best!
Best regards,
Old   January 29, 2010, 04:44
Claus Meister
idrama is on a distinguished road
Hey foamers!
Could anybody tell me please, how to store the matrices A and H into a file? I would like to have a look. Or is there even a better possibility so see them?
Cheers,
Claus
idrama is offline   Reply With Quote
Old   January 29, 2010, 05:34
Kathrin Kissling
Hello Claus,
have a look into fvMatrix.H its defined there:
volScalarField matrix.A()
tmp< GeometricField< Type,
fvPatchField, volMesh > > matrix.H()
Hope this helps!
Best
Kathrin
Old   February 5, 2010, 02:15
Default help
  #14
mohsen kh
mohsenkh599 is an unknown quantity at this point
Hi Foamers
I am an amateur and I want to simulate viscoelastic fluids flow, But I am completely confused with OpenFOAM. And a lot of questions arise for me working with this software. Would you possibly answer some of my questions?
1.For implementing a new model (like LPPT) is it sufficient to write a new application in (OpenFOAM/applications) or it is necessary to modify OpenFOAM/src and/or lib and/or etc.
2. Could you possibly send me one or more new application file which you have made it by yourself (a viscoelastic model for instance). Or a detailed help about implementing new models in OpenFOAM?
I do need your help. Please help. That’s for my master thesis.
Best wishes
Mohsen – m.kh.599@gmail.com
mohsenkh599 is offline   Reply With Quote
Old   February 5, 2010, 07:30
Mohsen,
first try to read at least User and Programmer guides, that would help you to avoid such questions.
Good luck!
Best regards,
Old   March 20, 2010, 15:27
YS
Ya_Squall2010 is on a distinguished road
Hi, mkraposhin
I was wondering where can we find the mathematical derivation of this treatment or justification? Thanks a lot!
Ya_Squall2010 is offline   Reply With Quote
Old   April 18, 2010, 08:46
Default help
  #17
mohsen kh
hi
how can I implement following equation in OpenFoam:
tau_=-2*C*(d(phi)/d(C))
I mean the derivative of phi (a variable) relative to C (a matrix)
the best
Old   April 18, 2010, 08:53
Default help
  #18
mohsen kh
hello again
when compiling a code I get the following message :
mohsen@mohsen-laptop:~/OpenFOAM/OpenFOAM-1.6/src/transportModels$ ./Allwmake
+ wmake libso incompressible
'/home/mohsen/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleTransportModels.so' is up to date.
+ wmake libso interfaceProperties
'/home/mohsen/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libinterfaceProperties.so' is up to date.
+ wmake libso viscoelastic
wmakeLnInclude: linking include files to ./lnInclude
make: *** No rule to make target `viscoelasticLaws/Conf/Conf.dep', needed by `Make/linuxGccDPOpt/dependencies'. Stop.
whats the problem?
the code is as follows:
#include "Conf.H"
#include "addToRunTimeSelectionTable.H"
namespace Foam
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
defineTypeNameAndDebug(Conf, 0);
addToRunTimeSelectionTable(viscoelasticLaw, Conf, dictionary);
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
// from components
Conf::Conf
const word& name,
const volVectorField& U,
const surfaceScalarField& phi,
const dictionary& dict
viscoelasticLaw(name, U, phi),
C_
IOobject
"C" + name,
U.time().timeName(),
U.mesh(),
IOobject::MUST_READ,
IOobject::AUTO_WRITE
U.mesh()
tau_
IOobject
"tau" + name,
U.mesh(),
IOobject::NO_READ,
U.mesh(),
dimensionedSymmTensor
"zero",
dimensionSet(1, -1, -2, 0, 0, 0, 0),
symmTensor::zero
I_
"I",
dimensionSet(0, 0, 0, 0, 0, 0, 0),
symmTensor
1, 0, 0,
1, 0,
1
rho_(dict.lookup("rho")),
etaS_(dict.lookup("etaS")),
etaP_(dict.lookup("etaP")),
M_(dict.lookup("M")),
lambda_(dict.lookup("lambda")),
// * * * * * * * * * *t * * * * * Member Functions * * * * * * * * * * * * * //
tmp<fvVectorMatrix> Conf::divTau(volVectorField& U) const
dimensionedScalar etaPEff = etaP_;
return
fvc::div(tau_/rho_, "div(tau)")
- fvc::laplacian(etaPEff/rho_, U, "laplacian(etaPEff,U)")
+ fvm::laplacian( (etaPEff + etaS_)/rho_, U, "laplacian(etaPEff+etaS,U)")
void Conf::correct()
// Velocity gradient tensor
volTensorField L = fvc::grad( U() );
// Transpose of grad(U)
volTensorField LT = fvc::L.T();
// Twice the rate of deformation tensor
volSymmTensorField twoD = twoSymm( L );
// C . gamma
volTensorField moh1 = twoD & C_;
// gamma . C
volTensorField moh2 = C_ & twoD;
// vorticity
volTensorField vor = L - LT;
volTensorField moh3 = vor & C_;
volTensorField moh3 = C & vor;
// Evolution of orientation
tmp<fvSymmTensorMatrix> tauEqn
fvm::ddt(tau_)
1/4*(moh1+moh2)
-1/4*(moh3+moh4)
tauEqn().relax();
solve(tauEqn);
// Evolution of the backbone stretch
tmp<fvScalarMatrix> pheeEqn
phee
(lambda/2)*Foam::sqr(tr((I - inv(C))/2))
+ M*Foam::sqr(tr((I - inv(C))/2))
pheeEqn().relax();
solve(pheeEqn);
// Viscoelastic stress
tau_ = -2*C_*fvm::ddt(C);
} // End namespace Foam
thank you very much
Old   June 16, 2010, 12:44
flowris is on a distinguished road
A little suggestion: sometimes people forget to run "wclean" before "wmake", provoking the error you had.
flowris is offline   Reply With Quote
Old   December 14, 2011, 21:39
Smile Why grad(U)().T() and not grad(U).T()
  #20
Rui Vizinho de Oliveira
RuiVO is on a distinguished road
Hello Foamers. This thread is a very usefull one indeed. I still have two questions though.
Why is it written :
dev2(fvc::grad(U)().T()) instead of dev2(fvc::grad(U).T())
Why the extra pair of parenthesis ??
The other question is what is the meaning of "twoSymm" in the following expression:
dev(twoSymm(fvc::grad(U_)))
Best Regards
Rui
RuiVO is offline   Reply With Quote
OpenFoam programming prapanj OpenFOAM 10 March 18, 2010 07:23
Programming in OpenFOAM vinu OpenFOAM 2 July 11, 2009 10:16
two questions about udf programming Vincent FLUENT 1 October 5, 2008 00:24
new CFD Programming Forum Thinker Main CFD Forum 14 November 19, 2002 16:03
Programming in C Tony Main CFD Forum 5 March 7, 2002 12:40
