Better understanding of some unknown parameters in scalarcodedsource
Old   June 6, 2015, 14:25
Default Better understanding of some unknown parameters in scalarcodedsource
Mehdi Asghari
Asghari_M is on a distinguished road
Hello everyone!
I used scalarCodedSource for definition of a transient heat source.
However, I can't understand the usage of some parameters assigned within the code.
For example, what is meaning of the -= sign at codeAddSup?
If It adds an additional source term to main S= S_u + S_p x, what's philosophy of the minus sign at it?
Or as second question, is codeAddSup an absolute quantity or a specific one?
Or as third question, what’s the meaning of sourceTimeCoeffs in this dynamic code?
Also, these ambiguous parameters are highlighted with red color at a sample scalarCodedSource as follows:
energySource
type scalarCodedSource;
activetrue;
selectionMode all;
scalarCodedSourceCoeffs
fieldNames(h);
redirectType sourceTime;
codeInclude
codeCorrect
Pout<< "**codeCorrect**" << endl;
codeAddSup
const Time& time = mesh().time();
const scalarField& V = mesh_.V();
scalarField& heSource = eqn.source();
heSource -= 0.1*sqr(time.value())*V; // Is specific or absolute?
codeSetValue
Pout<< "**codeSetValue**" << endl;
// Dummy entry. Make dependent on above to trigger recompilation
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue
sourceTimeCoeffs
// Dummy entry
Thanks a lot for any help
Asghari_M is offline   Reply With Quote
Old   June 7, 2015, 09:23
Avdeev Evgeniy
j-avdeev will become famous soon enough
Send a message via Skype™ to j-avdeev
Hello, Asghari.
As I remember C++, the following line
mean the same as
heSource = heSource - 0.1*sqr(time.value())*V;
j-avdeev is offline   Reply With Quote
Old   June 8, 2015, 04:50
Mehdi Asghari
Ok, of cource this is obvious.
However I didn't get my answer. As a better explanation of my questions, I can restate it as following question:
Suppose there is an energy source term in a simple solid conduction problem according to the following form:
S(h)= t/(t+1)*0.5 (unit is watt/m3 ) :: specific energy source, and
Simple Conduction Equation: ddt(rho, h) - laplacian (k/Cp, h) = enthalpy source term
Now, I want to use scalarCodedSource for definition of heat (enthalpy) source term.
How can I do this operation?
Moreover, the meaning of other unkown parameters such as codeCorrect and sourceTimeCoeffs are still ambiguous for me.
I have presented scalarCodedSource as follows:
( note that I have pointed all of my questions and doubted options for source term and other unknown parameters with red color)
 energySource
active true;
selectionMode all;
fieldNames(h);
codeInclude
codeCorrect
codeAddSup
// which expression is correct for above mentioned energy source term??:
// heSource = time.value()/(time.value()+1)*0.5; //first option (Is it answer?)
// heSource = time.value()/(time.value()+1)*0.5*V; //second option(Is it answer?)
// heSource -= time.value()/(time.value()+1)*0.5;// third option(Is it answer?)
// heSource -= time.value()/(time.value()+1)*0.5*V;// forth option(Is it answer?)
codeSetValue
code
$codeInclude
$codeCorrect
$codeAddSup
$codeSetValue ?
sourceTimeCoeffs ?
// Dummy entry
As you consider, the difference between second and third expression at above code is at using or non-using of minus sign.
Thanks a lot for any other help.
Old   July 30, 2015, 05:03
nemo
huyidao is on a distinguished road
I also face the same problem right now,do you get the answer?
huyidao is offline   Reply With Quote
Old   July 30, 2015, 12:53
Mehdi Asghari
Hi!
Just now, some similar discussions is being discussed in following thread:
http://www.cfd-online.com/Forums/ope...rce-terms.html
You might want to consult the above mentioned thread.
Old   July 30, 2015, 21:18
nemo
Thank you very much.
I still do not understand this problem totally,I think I should read the source code and try to get the answer.
Old   October 16, 2018, 03:32
SomeUser is on a distinguished road
Hi All,
I'm using reactingMultiphaseEulerfoam 3.0 with the fvOptions, scalarCodedSource.
I would like to have two sources, one that is a sink and removes some phase 1 and another source that adds the same mass amount of phase 2.
The mass removed should be dependent on the mass of phase 1.
aka dm1/dt=m1*A
Do someone has any idea how it would be best to do it?
Thanks!
SomeUser is offline   Reply With Quote
scalarcodedsource
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
[Other] How to create an MRF zone ? aminem OpenFOAM Meshing & Mesh Conversion 2 December 8, 2014 10:45
Thermal Comfort Simulation in STAR CCM+ anupmu STAR-CCM+ 1 February 27, 2013 14:25
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
