How about I write U by reconstruct(phi)?
Old   September 3, 2013, 21:14
Default How about I write U by reconstruct(phi)?
Dongyue Li
sharonyue is on a distinguished road
Hi Foamers!
Wonderful day!
lol, AFAWK, in the algorithm, we can get the U after solving possion equation via this equation: U = HbyA - rAU*fvc::grad(p);
In OpenFOAM, We all know that phi is divergence free indtead of U, Well, how about writing U by myU = fvc::reconstruct(phi)? Shouldn't it be more precise?
I made a test on cavity, there is a little difference but not much.
sharonyue is offline   Reply With Quote
Old   September 5, 2013, 05:21
Dongyue Li
Hello guys??
Old   September 11, 2013, 04:49
Dongyue Li
Any ideas?
Old   September 17, 2013, 09:55
A. Bernath
derkermit is on a distinguished road
Shouldn't reconstruct just (linear) interpolate the face centered values of (in this case) phi to the cell centers?
Do you get the same dimensions for myU and U?
derkermit is offline   Reply With Quote
Old   September 22, 2013, 21:30
Dongyue Li
Yep, its the same. And it surely interpolate the phi to the cell centers. Just as OpenFOAM make sure phi is divergence free. So I think myU would be more precise than U. but as of the algorithm, U can be get by another equation. So I'm wondering which method would be more precise.
Old   September 23, 2013, 06:28
A. Bernath
How can they both have the same dimensions?
As an example: reconstruct(T) would give me the linear interpolated cell centered temperature values from face centered values. That will not affect the units or am I wrong with this?
If not, why would you get the same dimensions for myU and U?
Old   September 23, 2013, 20:41
Dongyue Li
I dont know if you can do reconstruct(t), but you can do reconstruct(phi) then you would get U at the cell center. more details see here and welcome comments: http://www.cfd-online.com/Forums/ope...-two-same.html. so myU 's unit,which is get by reconstructing, would be the same with U.
Actually, I have to make a new file in time file. I just copy U and rename it by myU.
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 13:06
[Helyx OS] Helyx-OS (GUI for SnappyHexMesh elvis OpenFOAM Community Contributions 210 January 30, 2017 18:57
How to write UDF programme inside FLUENT? coolyihao Fluent UDF and Scheme Programming 9 June 5, 2016 21:08
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Problem when I try to write the geometry file massimo Siemens 0 January 14, 2003 04:58
