If there are some codes can let every mesh read the transproperties? |
October 26, 2013, 03:38 |
salame ama
Rep Power: 13 |
Hi, Formers:
In my case, i want every mesh can read the file like transproperties, actually viscoelasticproperties , the viscoelasticproperties file includes some scalar quantities which describe the properties of melt, but unequal in every mesh because different temperature. That is my idea about my case, is that possible and how can i get that? Best regards! salame |
November 3, 2013, 13:53 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Salame,
With multiple meshes, you can always use the Code:
const dictionary& otherMeshTransportProperties = mesh1.thisDb().parent().subRegistry(<nameMesh0>) .lookupObject<IOdictionary>("transportProperties"); Kind regards Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
November 4, 2013, 02:30 |
salame ama
Rep Power: 13 |
Thank u! Niels, i will have a try !
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
[Other] Cannot read a Spider mesh into Foam | evrikon | OpenFOAM Meshing & Mesh Conversion | 1 | March 14, 2012 10:13 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Converting Starccm+ mesh | Ladnam | OpenFOAM | 0 | September 14, 2011 06:30 |
