Read fields from viscosity model
Old   November 20, 2013, 06:45
Question Read fields from viscosity model
Gaetano
Gaetano is on a distinguished road
Hi all.
I'm having a I/O related problem. To put it simple: I need to read some scalar fields defined in the main solver (based on interFoam, OpenFOAM 2.1.1).
Here's what I've done (myModel.C):
// * * * * * * * * * * * * Private Member Functions  * * * * * * * * * * * * //
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::myModel::calcNu() const
    const volScalarField& myField = U_.db().lookupObject<volScalarField>("myField");
//    THE SAME WITH:
//    const volScalarField& myField = U_.mesh().lookupObject<volScalarField>("myField");
    return
        min
            nu0_,
            //MY FUNCTION GOES HERE
Both the viscosityModel (wmake libso) and the solver compiles without errors/warnings.
Here's the output of the simulation:
Reading transportProperties
./mySolver: symbol lookup error: ./mySolver: undefined symbol: _ZN4Foam15twoPhaseMixtureC1ERKNS_14GeometricFieldINS_6VectorIdEENS_12fvPatchFieldENS_7volMeshEEERKNS1_IdNS_13fvsPatchFieldENS_11surfaceMeshEEERKNS_4wordE
The field is defined (in createFields.H, before defining "twoPhaseProperties") as:
    volScalarField myField
        IOobject
            "myField",
            runTime.timeName(),
            mesh,
            IOobject::MUST_READ,
            IOobject::AUTO_WRITE
        mesh
What am I doing wrong? What does that error mean? Are those weird sequence of character interpretable or not (I found here that 1ERKNS is the representation base 33 of the number 56731153!!!)?
Another question: how can I access the overall rho field from within my viscosity model?
Thanks in advance
Gaetano
Gaetano is offline   Reply With Quote
Old   November 20, 2013, 08:51
Bernhard
Bernhard is on a distinguished road
I think what you need, is probably to look up the fields from the object registry database, which you can access via the mesh.
There are multiple topics that should help you find how to do it, using these keywords
http://www.cfd-online.com/Forums/ope...-registry.html contains a lot of info.
Bernhard is offline   Reply With Quote
Old   November 21, 2013, 05:29
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hi Gaetano and Bernhard,
I'm dealing with the same problem.
- In incompressible models, the viscosity object constructor contains the reference of the volScalarField U. So we can define an object "mesh" :
mesh& myMesh = U.mesh();
And then with look up object, we can get everything (not tested, but I guess it may be right) :
volScalarField& T = myMesh().lookupObject<volScalarField>("T");
- Now for compressible models. The constructor doesn't contain any volVectorField or volScalarField. And the function "mu()" takes only two scalars p and T in arguments.
How can I get an access to the mesh without modifying the transport object's constructor ?
I also saw this :
const volVectorField& U = obr_.lookupObject<volvectorField>("U");
But I need to find out how to declare the object "obr_".
Aurelien Thinat is offline   Reply With Quote
Old   November 26, 2013, 12:37
Gaetano
As said by Bernhard and Aurelien it is possible to access fields in this way:
For future reference, a useful step-by-step tutorial is this implementation of a temperature dependent viscosity model.
Thanks for your help!
interfoam, ioobject, read fields, viscosity models
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Phase change PYJG CFX 10 November 19, 2013 07:59
Piecewise viscosity model awacs OpenFOAM Running, Solving & CFD 3 June 21, 2010 23:10
Questions about Cross-Arrhenius and Cross-WLF viscosity model awacs OpenFOAM Running, Solving & CFD 4 August 13, 2009 06:56
