adapting sprayDyMFoam-solver to OpenFOAM-2.2.x |
December 9, 2013, 11:12 |
Sasa Milojevic
Hi everyone,
as the title tells you I'm trying to adapt an existing sprayDyMFoam-solver from OpenFOAM 2.1.x to 2.2.x . As you surely know there have been some changes concerning the amount and names of Header-files in OpenFOAM, this is the reason why the 2.1.x-Version of sprayDyMFoam won't work on 2.2.x . The changes I've done so far: - added missing header-files - header-files which don't exist in 2.2.x were commented out and partly replaced by 2.2.x header-files - renamed hsEqn.H to EEqn.H for consistency reasons - changed the content of some header-files ( pEqn.H, EEqn.H, YEqn.H etc.), because of the version differences between 2.1.x and 2.2.x - replaced the function sources() with fvOptions() When I tried to compile the solver some issues ocurred. Example: sprayDyMFoam.C: (.text + 0x7a19): undefined reference to `Foam::fv::IOoptionList::IOoptionList(Foam::fvMesh const&)' See also attached log.wmake-file. Does anyone had the same problem or know how to fix it? Attached you'll find the original and the adapted solver as well as the compilation log-file. Thank you in advance. |
December 20, 2013, 07:14 |
Sasa Milojevic
Hi everyone,
I found the initial issue. Some libraries haven't been linked by me and some small adjustments had to be made. I also didn't validate it yet. If there are some news i'll post them here. |
compile, dynamic mesh, issue, sprayfoam |
[OpenFOAM.org] openfoam 2.2.x - mesquite 2.3.0 | joegi.geo | OpenFOAM Installation | 3 | February 27, 2017 10:20 |
Edit linear solver | luckycfd | OpenFOAM Programming & Development | 32 | January 24, 2014 13:28 |
Finally starting to explore OpenFOAM, questions on icoFoam solver... | JasonG | OpenFOAM Running, Solving & CFD | 20 | July 11, 2012 20:08 |
FSI solver in openFoam 1.6.x | aut_iut | OpenFOAM Running, Solving & CFD | 1 | July 14, 2010 03:38 |
AMG solver in Openfoam | gonski | Main CFD Forum | 0 | November 25, 2007 05:20 |
