void Foam::multiphaseSystem::solve() of multiphaseEulerFoam solver
hi,
within method solve() can be found: Code:
... Code:
const fvMesh& mesh_ and solutionDict() [Return the selected sub-dictionary of solvers if the "select" keyword is given, otherwise return the complete dictionary.] : Code:
const Foam::dictionary& Foam::solution::solutionDict() const and subDict("PIMPLE") [Find and return a sub-dictionary for manipulation.] Code:
Foam::dictionary& Foam::dictionary::subDict(const word& keyword) 1A. mesh_ is a reference to the fvMesh which consists of many subobjects. When calling method solutionDict() on mesh_ what is method found("select") actually doing and if it is searching for the word "select" where in fvMesh mesh it is searching for it? 1B. Method solutionDict() : What is exactly meant by the "select" keyword? solutionDict() does not get any input parameters and therefore I assume it is really searched for a dictionary called "select"... 2. Assumed method solutionDict() returns the reference to mesh, hence mesh_ (see line 349 to 351 second code snippet) method subDict("PIMPLE") afterwards searches for a dictionary called "PIMPLE" in fvMesh mesh? Perhaps I am misinterpreting something here? I hope someone enlightens me :). greetings maybee |
Hello Maybee,
Did you find answers for your questions here? |
I am not sure since I worked with the solver a long time ago, but I don t think I could get any answers to these questions. Best Regards |
