Calculating the explicit terms of div(phi,U)
Like Tree1Likes
  • 1 Post By yeharav
Old   December 16, 2019, 01:17
Default Calculating the explicit terms of div(phi,U)
yeharav is on a distinguished road
Hi all,
I am trying to calculate the individual terms of the convection terms in post-process.
The convection term is the vector
fvc::div(phi,U).
The convection term evaluated on the surface works fine
fvc::div(phi*fvc::interpolate(U))
However, when I use
fvc::grad(phi*fvc::interpolate(U))
and take components 0,1 and 2
the results are not related to anything. Infact even just component 0 is not related to anything.
Any ideas?
yeharav is offline   Reply With Quote
Old   December 19, 2019, 13:19
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
gradient of a vector is a tensor, not another vector.
HPE is offline   Reply With Quote
Old   March 16, 2020, 05:53
Default Solution
I have solved this a while ago but I think its a good thing to post the solution here if somebody will ever need it.
So, as HPE mentioned the result is indeed a tensor. This is what we are trying to calculate.
That is we want a tensor whose [i.j] item /\frac{\partial u_i u_j}{dx_i}.
As I mentioned, just taking fvc::grad(phi*fvc::interpolate(U)) is erroneous.
There are several reasons for that:
1. phi is already multiplied by the surface area of the cell and therefore calling fvc::grad
multiplies it twice.
2. There are some correction for the boundary conditions.
Using the gauss term we try to calculate the surface integral of
/u_i u_j\cdot n. So the question is now to evaluate these
fields on the cell face that is consistent with the way OF calculate the div(phi,U) term.
My solution is:
First calcualte the tensor terms on the face of each cell.
 surfaceTensorField interpolateUU    =   (phi*mesh.Sf()/mesh.magSf()))*fvc::interpolate(U);
Note that phi is scalar and
is the vector that is normal to the face direction (whose length is 1).
Now we need to correct the boundary fields.
forAll(mesh.boundary(), patchi)
		auto& boundary_interpolateUU 	= interpolateU2.boundaryFieldRef()[patchi];
		const auto& boundary_phi	     = phi.boundaryField()[patchi];
		const auto& boundary_interpolateU    = interpolateU.boundaryField()[patchi];
		const auto& boundary_mesh 	     = mesh.boundary()[patchi];
		forAll(boundary_mesh, facei)
		    vector n_inside = -(boundary_mesh.Sf()[facei]/boundary_mesh.magSf()[facei]);
		    tensor tt = (boundary_phi[facei]*n_inside )*boundary_interpolateU[facei];
		    for (int i=0; i<9;i++) {
				boundary_interpolateUU[facei].component(i) = tt.component(i);
Finally, we can calculate the value of the flux using th surface integral.
fvc::surfaceIntegrate(interpolateUU);
Daniel_Khazaei likes this.
rotational and inviscid Mike Main CFD Forum 40 November 9, 2023 06:03
Implicit vs Explicit Houthuys Main CFD Forum 15 February 3, 2017 11:17
Explicit filtering in LES TJ Main CFD Forum 85 November 30, 2016 05:22
The terms that should be treated implicitly in LES ben Main CFD Forum 3 January 28, 2005 03:32
K-Epsilon model? Brindaban Ghosh Main CFD Forum 2 June 24, 2000 04:22
