adapting sprayDyMFoam-solver to OpenFOAM-2.2.x
Old   December 9, 2013, 11:12
Default adapting sprayDyMFoam-solver to OpenFOAM-2.2.x
Sasa Milojevic
SasaM is on a distinguished road
Hi everyone,
as the title tells you I'm trying to adapt an existing sprayDyMFoam-solver from OpenFOAM 2.1.x to 2.2.x . As you surely know there have been some changes concerning the amount and names of Header-files in OpenFOAM, this is the reason why the 2.1.x-Version of sprayDyMFoam won't work on 2.2.x .
The changes I've done so far:
- added missing header-files
- header-files which don't exist in 2.2.x were commented out and partly replaced by 2.2.x header-files
- renamed hsEqn.H to EEqn.H for consistency reasons
- changed the content of some header-files ( pEqn.H, EEqn.H, YEqn.H etc.), because of the version differences between 2.1.x and 2.2.x
- replaced the function sources() with fvOptions()
When I tried to compile the solver some issues ocurred.
Example: sprayDyMFoam.C: (.text + 0x7a19): undefined reference to `Foam::fv::IOoptionList::IOoptionList(Foam::fvMesh const&)'
See also attached log.wmake-file.
Does anyone had the same problem or know how to fix it?
Attached you'll find the original and the adapted solver as well as the compilation log-file.
Thank you in advance.
SasaM is offline   Reply With Quote
Old   December 20, 2013, 07:14
Sasa Milojevic
Hi everyone,
I found the initial issue. Some libraries haven't been linked by me and some small adjustments had to be made.
I also didn't validate it yet. If there are some news i'll post them here.
compile, dynamic mesh, issue, sprayfoam
[OpenFOAM.org] openfoam 2.2.x - mesquite 2.3.0 joegi.geo OpenFOAM Installation 3 February 27, 2017 10:20
Edit linear solver luckycfd OpenFOAM Programming & Development 32 January 24, 2014 13:28
Finally starting to explore OpenFOAM, questions on icoFoam solver... JasonG OpenFOAM Running, Solving & CFD 20 July 11, 2012 20:08
FSI solver in openFoam 1.6.x aut_iut OpenFOAM Running, Solving & CFD 1 July 14, 2010 03:38
AMG solver in Openfoam gonski Main CFD Forum 0 November 25, 2007 05:20
